Removing Unilite Electronic Conversion
Old Oct 21, 2017 | 11:03 AM
69L71's Avatar
69L71
Default Removing Unilite Electronic Conversion
I am very frustrated with my Unilite. It was installed in my 66 when I got it and it ran ok at first, but the car periodically shuts down and won't start. I'll tow it home or leave it and come back later, and sometimes it will start. I've swapped out coils, checked all grounds, and banged my head against the wall. The next obvious change is the unilite itself. I understand they're not the most reliable so maybe it's the problem all along.
I'm seriously considering going back to points. I know lots of folks will balk at that idea, but they're cheap and reliable, so why not? The question is, the breaker plate gets removed when you install a unilite, so I can't just pop points back in. Where can I get a replacement breaker plate? Do I have to disassemble the whole centrifugal advance mechanism to get the breaker plate back in?
Thanks in advance for your help.
Old Oct 21, 2017 | 11:18 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Forget going back to points. Put in a HEI unit.
Old Oct 21, 2017 | 11:23 AM
redvetracr's Avatar
redvetracr
I believe the uni-light attaches to the same holes in the breaker plate as the points did
Old Oct 21, 2017 | 11:44 AM
71VetteLover's Avatar
71VetteLover
When an engine mysteriously "shuts down" there are many possible causes and here are just some of them:
1. Plugged sock filter in gas tank.
2. Plugged inline filter (if one is installed)
3. Plugged filter in inlet of carburetor
4. Failing fuel pump.
5. Fuel hose sucking shut or coming apart inside.
6. Gas tank not vented.
7. Bad ignition switch.
8. Bad coil.
9. Bad electrical connection.
10. Gas tank not vented.
11. Insufficient gas in tank.
I have seen many cases in which an ignition switch is bad and after it warms up the power going to the coil simply shuts off. After the switch cools off the engine can be started again and after another 30 minutes the switch will get warm enough to shut the power off again and so on.
Old Oct 21, 2017 | 12:19 PM
69L71's Avatar
69L71
It is definitely NOT a fuel system problem. Fuel is getting to the carb and into the engine. That I know, but even to make sure I tried spraying starting fluid. Still no start. Not even a cough. Finally I pulled a spark plug cable and cranked it to see an arc. Nothing. As I said, I swapped coils (three actually). All worked at one time or another and not others. A good sign of being unrelated. The only thing on your list that might still apply is the ignition switch.
I considered the hot condition source at first, but it's not that. Car has been sitting for 3 weeks and won't start. Can't get cooler than that.
Pretty sure it's distributor related and the unilite has been known to crap the bed. Seems the next logical step. OEM HEI is not an option because it won't fit under the factory ignition shielding.
Old Oct 21, 2017 | 12:42 PM
dmaxx3500's Avatar
dmaxx3500
if you don't want it,,i'll take it
I hate points
Old Oct 21, 2017 | 02:14 PM
lars's Avatar
lars
I run good quality points in every distributor I build. The UniLite system attaches to the stock breaker plate, so you don't need a new plate. You just need the hardware. Hardware is available through NAPA under part number 665-1133. Good points are part number CS-786. Condenser is part number RR-175. You'll also need a new lead wire, part number LW-72. The rubber grommet is available from Paragon Reproductions under part number 5786. I have a box full of UniLite and PerTronix conversions that I have pulled out of people's distributors - they never want them back after going to a performance points setup.
Lars
Old Oct 21, 2017 | 05:27 PM
1Fordman's Avatar
1Fordman
It's probably the unilite module, they have a history of doing what your symptoms are. I ran unilite's in a couple of past cars but carried a spare module because they did die out on the road.
As Lars said a good point ignition works well.
I'm running HEI in the 68 and it's problem free.
Old Oct 23, 2017 | 04:34 PM
69L71's Avatar
69L71
Great info. Thanks Lars!
I'll get to Napa and get these parts ordered. Of course leave it to Paragon to charge $11.50 on a $2 part. I might have to work around that....
I'll post back once I get the distributor fixed!
Old Oct 23, 2017 | 05:05 PM
7T1vette's Avatar
7T1vette
When ANY electronic ignition system fails, you walk home.
When points ignitions starts to get worn or condenser starts to fail, you get some ignition 'miss' problems. But, you still can drive home. With the 2000 or so miles I put on a car during the year, that means cleaning and adjustment over the winter until ignition starts to miss. Change points and condenser and it's all good for another few years.
Old Oct 24, 2017 | 06:47 PM
wilcar's Avatar
wilcar
Time to send it to Lars for a REAL rebuild!
Old Oct 24, 2017 | 08:37 PM
sunflower 1972's Avatar
sunflower 1972
Old Oct 24, 2017 | 11:40 PM
Green73's Avatar
Green73
I 'upgraded' to a pertronix on another car (non-vette) that left me stranded many times. I replaced the pertronix at least twice (yes, i had the ballast resister to drop the voltage too).. The last time, after shamefully pushing my car out of the drive thru, I walked to the parts store that happened to be in the same parking lot that I broke down in, bought a set of points and condenser for under 12 bucks, replaced the fancy do-hicky with tried and true mechanical ignition. Best 12 bucks I ever spent and saved me the cost of a tow home and rather proud of myself at 19 and able to do such before the age of cell phones and forums. (not as long ago as you think).
For the most part, our cars are not driven that frequently, and points aren't as big of a pain as some people let on. They're simple, they're cheap, they're easy to install (screwdriver and a matchbook.... if you can find a matchbook still) and they're still readily available. I don't frown on anyone switching back... it sure beats walking.
Old Oct 25, 2017 | 03:57 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Sounds like you're comparing apples to oranges here (failing versus "starting to fail"). I've had an (aftermarket) electronic ignition system "start to fail" years back, and I drove it quite a while before I had time to debug it.
I replaced that ignition module with a genuine Delco ignition module, and I haven't had to "clean and adjust" anything in the distributor (other than the distributor cap terminals) in years.
Old Nov 4, 2017 | 05:29 PM
69L71's Avatar
69L71
OK Lars.
I got all the parts and have the distributor back together. Thanks for the parts list. The only one I added was a new ground wire to match my lead wire, but since my distributor was gutted I'm not sure where this goes.
Any pointers?
Old Nov 4, 2017 | 11:35 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I jerked the MSD and Pertronix outta my 68 L36 years ago and put in a set of points.
I think I lost 100 HP, right?
All kidding aside, I somehow appreciate the originality of the points. Either will work...
It was funny going to O'Reilly and asking for points. In the old days there 5 or more brands to pick from, depending on your $$. They had exactly 1 set of points in the store.
Old Nov 5, 2017 | 08:34 AM
gkull's Avatar
gkull
Do you have it wired correctly with a ballast resistor. About a 12 dollar item from summit
have you replaced the optical module. Again cheap at summit racing
I've used unilite on all kinds of applications without a problem
To Removing Unilite Electronic Conversion
Old Nov 5, 2017 | 06:23 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
This is critical if not running a box........the Unilite opti eye is only suppose to have 7 volts going to it....wire it direct and it WILL burn out eventually. I kept these 10 deep on the wall at the speed shop years ago and would sell five every Saturday......and try to explain the ballast (which I carried as well) to the customer. About 1 in 5 would bite.
At $90 a pop.....you think folks would learn.
Anyway....wire in a ballast and happy trails.
Jebby
Old Nov 5, 2017 | 07:13 PM
69427's Avatar
69427
Jebby
A ballast isn't going to provide a 7 volt supply for the optical unit. In the non-dwell periods during operation there's going to be pretty much 12 volts at the ballast. A ballast is only there to limit the peak primary current to keep from blowing up any switching transistors in the control unit.
Old Nov 7, 2017 | 11:43 AM
gkull's Avatar
gkull
No matter what exactly the ballast resistor does it is critical in the functioning of certain distributers. It kinda dumb to take a step backwards to points. I was driving back when points cars were all we had and they left me stranded many times " I lived in a rainy area" Just going down the freeway in the rain and the motor shuts off. My one ford was the worst. Rain comes through the radiator and the dizzy is on the front of the motor. condensation fills the cap up and the spark quits.
when the first HEI's came out I switched out all my points ignitions
