1971 Headlight question
Old Oct 21, 2017 | 01:53 PM
ATHANASE's Avatar
ATHANASE
Default 1971 Headlight question
4 lights: 2 on each side. The inner lights only works as high beams. The outer lights light up both at low beam and at high beam. That is the way it should work, I guess.
My passenger side outer light does not light up at low beam but only at high beam. I wonder if it is a faulty bulb or a faulty connection. I can't tell if the light has two filaments in it (one for low and one for high beam) in which case, the low beam filament may just be fried. If there is only one filament however, that would mean that the problem is not in the bulb.
Any thought?
Old Oct 21, 2017 | 02:08 PM
dmaxx3500's Avatar
dmaxx3500
are you getting power to the socket?
Old Oct 21, 2017 | 02:57 PM
Alan 71's Avatar
Alan 71
Hi A,
There IS a difference between the outer/inner headlamps.
Outer:
High Beam and Low beam #4002.
Inner:
High beam #4001.
Perhaps..swap the 2 headlamps and you'll know if it's the lamp or not.
Regards,
Alan
Old Oct 21, 2017 | 03:22 PM
FirebirdStrip's Avatar
FirebirdStrip
I have the exact same issue today.. Except my driver's side high beam isn't working either, which may or may not be a bad light.
I will have to swap them as Allen suggested.
Let me know the outcome!
Old Oct 21, 2017 | 03:41 PM
ATHANASE's Avatar
ATHANASE
I am getting voltage between the top prong and the inner prong when on high beam only and none on the outer prong whether on high beam or low beam. I guess the outer prong is for low beam.
Old Oct 21, 2017 | 03:45 PM
ATHANASE's Avatar
ATHANASE
Originally Posted by Alan 71
Hi A,
Outer:
Inner:
High beam #4001.
Regards,
Alan
I thought of swapping the bulbs indeed but the plastic shroud in in the way and it looks like I can't remove it without removing the whole headlight set. I removed the four screws that hold the shroud in place but it is like a puzzle to get it out of that space. Any idea?
Old Oct 21, 2017 | 03:46 PM
71VetteLover's Avatar
71VetteLover
One of the prongs is a ground.
Old Oct 21, 2017 | 03:58 PM
Alan 71's Avatar
Alan 71
Hi A,
Typically the headlight bezel should be free to lift off once the 4 screws that attach it to the housing are removed.
Is the bezel 'trapped' by the opening in the hood surround?
Some times this is caused by the headlight not opening quite far enough.
Regards,
Alan
Old Oct 21, 2017 | 04:27 PM
ATHANASE's Avatar
ATHANASE
[QUOTE=Alan 71;1595808348]Hi A,
Is the bezel 'trapped' by the opening pin the hood surround?
Regards,
Alan
I would say it is because they do not open far or high enough. The bezel gets trapped indeed.
I have figured out the problem as to the bulb. I just need a new bulb. I will have to figure out the best way to get to it.
Thanks for the help.
Old Oct 21, 2017 | 04:31 PM
ATHANASE's Avatar
ATHANASE
Another question:
While working on the bulb issue, I have noticed that I have a spare female 2-prong socket that comes out of the headlight harness but is not connected to anything, just hanging there.
It is not for the park light nor for the marker light that are both connected and working. I wonder what it is for. I have one on the passenger side and one on the driver side. They get 12volts when I turn the lights on.
Any idea?
Old Oct 21, 2017 | 05:20 PM
theandies's Avatar
theandies
Hi A,
Outer:
Inner:
High beam #4001.
Regards,
Alan
Yup
Low beams should have 3 terminals on the bulb and high beams only have two.
Old Oct 21, 2017 | 05:23 PM
theandies's Avatar
theandies
Another question:
Any idea?
Light bucket warning switch. This tells you if one or both headlights don't open. There is a red light in the center right gauge cluster. There is probably a missing switch on the bucket mechanism. Alan71 will be here soon with a picture!
Old Oct 21, 2017 | 05:54 PM
Alan 71's Avatar
Alan 71
Hi,
Here's the headlight switch and it's electrical connection that 'ta' described.
When both of the doors are fully opened the switches shut off the headlight warning indicator located on the center gauge bezel.
Regards,
Alan
To 1971 Headlight question
