Im away from home right now, so dont have my shop manuals accessible.
Power door locks always worked fine. Sluggish, but locked and unlocked the doors fine for years. Today, seems there is no sign of power going to the locks. No click, no noise, nothing.
I checked the fuse that I think controls the door locks (CTSY 20a I believe), and its fine.
Any ideas on where to start trouble shooting this?
since both died at the same time then it's most likely one of the switches, or a connection problem somewhere.
You may have noticed a green, almost mold-like hue in the switch connectors. It is the normal corrosion due to the copper-on-copper design. It was pretty nasty looking. Our suppliers on the forum sell replacement pigtails. I used a dielectric grease at the connection to help arrest the natural corrosion.
I checked the fuse that I think controls the door locks (CTSY 20a I believe), and its fine. Any ideas on where to start trouble shooting this?
I don't think engineers thought these cars would last nearly 40 years and so some of those mechanicals were not well protected from the elements. Power door lock actuators have boots that once they break apart, the plunger gets corroded from exposure to moisture...and eventually seize up.
It may well be time to conduct some serious servicing of those units from the switch to the actuator to the linkage. I found with my 78, that gunk needed to be removed from linkage arms, actuator replaced and even the switch had frayed wires...rendering it unusuable.
This article is dated but explains the process for restoring the "power" function to the RPO AU3 Power Door Lock option.
