c3 4speed shifter mounting
Just replaced the clutch on my 71 4 speed,now its time to bolt in the shifter.My Question is The bottom hole on the bracket does the bolt go though into
the tranny.thanks
the tranny.thanks
On my 70 4-speed, the shifter mounts to a bracket and not to the transmission. Only the linkage attaches to the trans. Check yours - may be the same. There is a shifter bracket separate from the transmission. This is different then other 4 speeds I owned earlier such as a 67 Camaro. In that case the shifter bolted to the trans.
car71 (10-23-2017)
the bracket mounts to the cross member only.
car71 (10-23-2017)
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
If it is the factory shifter it mounts to a bracket which bolts to the crossmember. If it is aftermarket, such as Hurst, it will bolt to the side of the transmission.
car71 (10-23-2017)
Received 2,878 Likes
Hi c71,
Are you asking about bolting the shifter to the bracket or bolting the bracket to the crossmember?
The shifter body mounts to the shifter bracket with 2 bolts.
The upper bolt (the longer bolt) extends through the shifter body.
The lower bolt (the shorter bolt) only passes through a 'tab' extending down from the SHIFTER'S frame.
Regards,
Alan
Regards,
Alan
car71 (10-23-2017)
Hi c71,
Regards,
Alan
Regards,
Alan
