Starter Issue?
I climbed under the car and had a buddy turn the key. I swear the starer motor spins, just no Bendix engagement. I thought that possibly the Bendix was engaging, but the starter motor wasn’t strong enough to turn the engine, and that maybe the sound I was hearing was the starter motor “buzzing”. I seriously doubt this since the headlights work normally, and also, I would think the start motor would get very hot. However, I’m very open minded on this, but for now, I’m assuming it spins. It spins, then when letting go of the key, it winds down. I measured the voltage at the main battery connection on the solenoid and read 12.8VDC when they key was off. I then measured the voltage with the key rotated and starter motor spinning, and read 7.7VDC right at the main battery connection. I get very similar readings at the ignition switch terminal (on the solenoid) and also the ignition coil terminal. Does this sound correct? The starter motor sounds like it's spinning normally.
So I yanked the starter and removed the solenoid. I suspected the solenoid may have been weak and so wasn't throwing out the Bendix out to full sroke to engage the flywheel. But as I looked at how the mechanism works, I can't see how the actual starter motor can operate without the Bendix actuating fully. In the solenoid, there's a little button that when depressed, pushes a metal disk that makes contact between the main battery terminal and the starter terminal. It looks to me that the button can’t be depressed unless the metal cylinder (that connected to the Bendix linkage) throws fully (I plan to bench test the starter/solenoid this evening). I took measurents to see if it looked like the Bendix could indeed engage when at full stroke and everything looks fine. Any ideas? Thanks for your replies.
The Bendix should extend.
You can do the same test if the starter is in the car but disconnect the big positive cable first.
As far as the flywheel goes it sounds like you installed a smaller 153 tooth flywheel when it needs the larger 168 tooth flywheel.
There are several pictures around showing the differences in both internal and external balance flywheels/flexplates/harmonic balancers.
External Balance: https://www.bing.com/images/search?v...x=0&ajaxhist=0
Internal Balance: https://www.bing.com/images/search?v...x=5&ajaxhist=0
http://www.parts123.com/corvettecent...050g&ukey=8904
http://www.parts123.com/corvettecent...050g&ukey=8052
After you look at the correct flywheel in the top link, look up one there for a 1970 454 and it clearly shows the cast in offset balance weights in the pics. Think what that would do to your neutrally balanced 427.
