SFI flywheel
Old Oct 24, 2017 | 03:22 PM
c3_dk's Avatar
c3_dk
Default SFI flywheel
I'm doing a M21 to T5 swap right now. (69 L46 convertible)
My plan is to replace the factory 11" clutch flywheel, with a SFI 23lbs flywheel.
BUT I can see that the thickness of the factory flywheel is 30mm, the SFI is 23mm
I'm using the same clutch, will the 7-8mm difference give me problems?
Old Oct 24, 2017 | 03:31 PM
gkull's Avatar
gkull
You have to run a longer ball stud like the GM stock long ball stud and they're under $15
Old Oct 24, 2017 | 03:34 PM
c3_dk's Avatar
c3_dk
To be 100% sure I buy the right, can you send me a link?
Old Oct 24, 2017 | 04:31 PM
71VetteLover's Avatar
71VetteLover
Summit Racing stocks the different lengths.
Old Oct 24, 2017 | 05:10 PM
c3_dk's Avatar
c3_dk
As far as I can see, it is this one, it is 0.28" longer then std, I think std. is 1.5"
0.28" = 7.11mm
Correct??
https://www.ebay.com/itm/Chevrolet-P...BYOMQ-&vxp=mtr
Old Oct 24, 2017 | 06:40 PM
gkull's Avatar
gkull
Gm long ball stud 3790556. I never liked the adjusable type but they are an option
http://www.manchestermuncies.com/new...ball-stud.html
Old Oct 25, 2017 | 06:01 AM
c3_dk's Avatar
c3_dk
Great thx.
Here is what is it today.
Old Oct 25, 2017 | 03:38 PM
gkull's Avatar
gkull
GM 3790556 Clutch Fork Ball Stud (1 3/4 Long) Or 1.750 - 1.369 =.381 =9.6774 mm
You only needed 7-8mm, but a couple of mm is not a big deal. It is just the pivot point for your clutch fork rod. I installed a 21 pound SFI steel 168 tooth flywheel in front of my tko 600 and with the short ball stud sent by keisler the clutch would not disengage. So I went down to the local chevy dealer and bought the longer one
Old Oct 27, 2017 | 12:21 PM
c3_dk's Avatar
c3_dk
I bought GM 3790556 from Summit (easy for me to buy there)
So I hope I will have it next week, so I can install my transmission again.
Almost same flywheel here, 23 pound, 168 tooth, so I hope I can fell the change compared to the factory flywheel, but also with the first gear ration in the T5 compared to the "slow" M21
Old Oct 27, 2017 | 03:12 PM
buns's Avatar
buns
At 30mm, it appears you are measuring the total thickness of the flywheel. That is incorrect. This chart will explain:
Old Oct 27, 2017 | 06:27 PM
TimAT's Avatar
TimAT
Watch the flywheel bolts too- I just put an SFI 'wheel on my 496. The thickness of the hub was less and the ends of the flywheel bolts were way too close to the block for me. I cut about 3 threads off each bolt. Still have a couple of threads thru the flywheel flange.
Old Oct 28, 2017 | 01:22 PM
c3_dk's Avatar
c3_dk
Great info here !! THX !!
When I measure my stock 69 fly wheel, like picture number one it is 0.990" (picture says 0.960")
The SFI is 0.722"
0.990 - 0.722 = 0.268" = 6.8mm
And as George is saying "GM 3790556 Clutch Fork Ball Stud (1 3/4 Long) Or 1.750 - 1.369 =.381 =9.6774 mm"
6.8mm - 9.677 = 2.877mm
/John
Old Oct 28, 2017 | 03:55 PM
c3_dk's Avatar
c3_dk
Thx Tim, they clear the crankshaft, but I think I will take of 2mm or so, just to be sure.
Thx for the heads up !!
/John
Old Oct 28, 2017 | 06:23 PM
TimAT's Avatar
TimAT
You have about double what I had before I cut the bolts down.
FWIW: I just found the numbers for my clutch ball height:
Flywheel deck .690
The factory ball height 5.112 (Lakewood housing and block plate.
The factory ball height explains why I always had very little travel on the clutch adjustment.
I got a longer adjustable ball and got the height right back to the factory 4.75. Clutch adjustment is midway on the rod now.
Old Oct 29, 2017 | 02:51 AM
c3_dk's Avatar
c3_dk
Flywheel deck .690
I will check my factory ball height also. But I don't understand where to measure from (sorry I'm not from USA:- )
Where do I measure from, what is a block saver plate?
I think I will go for Nord Lock washers, that will give the 2mm I need compared to the factory washers.
http://www.nord-lock.com/nord-lock/w.../introduction/
Old Oct 29, 2017 | 11:39 AM
TimAT's Avatar
TimAT
The block saver plate fits between an explosion proof bell housing and the block. All for containment if the flywheel/clutch comes apart.
Lay a straightedge across the engine side of your bell housing so it's over the clutch pivot ball. Then measure from the mating surface to the top of the ball. Look at fig.2 on the red outline picture buns posted.
Old Oct 29, 2017 | 04:38 PM
buns's Avatar
buns
^ Exactly.
.960
-.722
=.238
4.75
-.238
=4.512
So, by my calculations (someone could double check), you need to set the ball height at 4.512"
I cleaned up the diagram, leaving out the block saver plate.
To SFI flywheel
Old Oct 29, 2017 | 04:57 PM
gkull's Avatar
gkull
Depending on who you talk to the gm long might be 1.68 or 1.75
Old Oct 29, 2017 | 10:20 PM
buns's Avatar
buns
Good point. There seems to be some confusion as to how they are measured. Centerforce suggests that this is the proper method.
Old Oct 30, 2017 | 01:52 PM
c3_dk's Avatar
c3_dk
Thx Tim
^ Exactly.
.960
-.722
=.238
4.75
-.238
=4.512
This is great, it was the block saver plate that got me confused
Thx gkull
Again buns, thanks for your help !!
