Cam Degreeing Question
Old Oct 26, 2017 | 07:04 PM
corvette_maniac's Avatar
corvette_maniac
Default Cam Degreeing Question
I am degreeing an XE-268 and the cam card call's for 28° BTDC @ .006 of lift on the #1 intake lobe. I am ***** dead on with that ... but my ICL is coming out lower than I would have expected (100). The LSA is 110 whilst the ICL is 106 for 4 degrees advanced .. built in. I verfied that I'm on true TDC with the degree wheel too.
Do I care about that ICL reading?
Old Oct 26, 2017 | 07:20 PM
71VetteLover's Avatar
71VetteLover
Are you checking it with the heads off or on? Did you use a piston stop to verify your timing tab is dead on?
Old Oct 26, 2017 | 07:50 PM
rklessdriver's Avatar
rklessdriver
Have you checked the closing point?
How are you calculating the centerline?
FYI if a cam with 268* of duration lifts the tappet .006@28*BTDC it has to be on 106 ICL.
Will
Old Oct 26, 2017 | 08:17 PM
corvette_maniac
I used a piston stop and found true TDC. That's step 1. The heads are on. Dial indicator is on the push rod. BTW - this is on my Firebird 400.
I'm getting the ICL by bringing the engine around to max lobe lift per the specs on the cam card ... I think it's .343. Anyhow ... I zero out the dial indicator then bring the cam down one side at .050, it's at 53° then bring it back up and down the other side ..050 and it's at 146°. Add the two and dividing by 2.
And no ... I am not worried about the timing tab at this point.
Old Oct 26, 2017 | 08:25 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Don't know how you nailed TDC #1 but I use something like 0.050" each side of TDC #1 and split the difference to zero the degree wheel (same method to set the timing pointer at zero also). Next if do want to verify ICL I use a solid lifter - has to be solid lifter - and use the same 0.050"/0.050" method for the intake lobe.
Yes it does get confusing when cam advance is built into the grind but you should be able to read it within 1/2 degree.
Hope this helps.
Also you don't need to zero out at max lift - just look for the same reading on both sides of the peak lift.
Old Oct 26, 2017 | 08:35 PM
corvette_maniac
I got TDC by splitting the difference of the dwell using a piston stop and degree wheel. Do I still need a solid lifter even though my dial indicator is right on the pushrod and the rocker arm is off? I can't imagine that with that setup that the plunger of the lifter is going to be depressed. I can see that I would need one if I were measuring off of the rocker arm with the spring being involved.
Old Oct 26, 2017 | 08:36 PM
corvette_maniac
Will
Sounds like I'm good.
Old Oct 26, 2017 | 09:56 PM
Neil B's Avatar
Neil B
If your actual measurements are 6 degrees off the 106 ICL, you're not good. Keep measuring until you are within 1 degree. Don't even worry about the other valve events until you get the intake centerline right. I don't think you can use a hydraulic lifter for this. I recommend the tool that inserts into the lifter bore instead of trying to measure off the standard lifter or pushrod.
Old Oct 26, 2017 | 11:25 PM
corvette_maniac
OK ... it appears that the XE cam intake lobes are asymmetric and leaning on the opening side. I think that would explain that. It's the only thing that makes sense since I'm dead on 28 degrees at .006".
Old Oct 27, 2017 | 03:01 PM
rklessdriver
Using the max lift then .050 on each side of max lift to check the lobe centerline will give incorrect results on a camshaft with Asymetrical lobes.... the only way to propely degree Asymetrical lobes is using then tappet timing events.
Will
Old Oct 27, 2017 | 06:18 PM
Neil B's Avatar
Neil B
Will
Makes sense. But if he's measuring on a hydraulic lifter with the dial indicator on the end of a pushrod, his measurement is likely the issue. I've found even when the cam is installed on the correct intake centerline, measured duration @.050 will still be off a few degrees.
Old Oct 27, 2017 | 09:16 PM
corvette_maniac
The lobe lift is .318 and when I zero out my DI on the base circle, I'm right on every time. That's a clear indicator to me that I'm not getting errant readings from using that lifter/pushrod.
Old Oct 27, 2017 | 11:36 PM
cardo0's Avatar
cardo0
I'm just not believing the nose of the cam lobe is all that asymmetric for 0.050". But if you are using a dial indicator on an accurate follower device and the degree wheel set up tight you should be able to easily see how many degrees 0.050" are on each side of max indicated lift.
They sell lifter follower tools now but thier not all that cheap. Myself I use 2 hydraulic lifters mated together with one inverted but this is too tall to use with the heads on. I read a lot of owners do the measurement at the p-rod but that looks way to error prone to me. In your case I would try to find a solid lifter to use.
Good luck.
Old Oct 28, 2017 | 10:09 AM
Neil B's Avatar
Neil B
I guess you could always move the centerline a few degrees and re-check the .050 valve events to see if they move with the centerline. At the end of the day, if the asymmetric lobe makes the centerline method invalid, then verify the IVC @.050 event. If that is where you want it (per cam card), then run it that way.
Old Oct 28, 2017 | 02:22 PM
corvette_maniac
The cam card doesn't have the .050 valve events; only the .006. The #1 opening is right on at 29° and the closing is at 54 ABDC but calls for 60 on the cam card. That's probably the only thing that concerns me. But then you can also see that the duration is 263 (@ .006) which is why the valve closing is 6 degrees early... and 220 (@ .050). Should I call it good .. or am I still off?
Here's what I have:
@ .050 9° BTDC
@ .050 31° ABDC
@ .006 29° BTDC
@ .006 54° ABDC
Old Oct 28, 2017 | 07:28 PM
corvette_maniac
OK ... so I need to retard the opening of the intake valve at .006 to 25.5 to get the ICL of 106.
Old Oct 28, 2017 | 11:41 PM
cardo0's Avatar
cardo0
Here's what I have:
@ .050 9° BTDC
@ .050 31° ABDC
@ .006 29° BTDC
@ .006 54° ABDC
I can see we have a misunderstanding here. I'm trying to describe 0.050" down from max lift but I see you are measuring 0.050" up from the base circle. Totally different measurements.
Also using that 0.050" lift point on an asymmetric lobe would then have a much larger discrepancy than a point that is 0.050" down from max lift on the nose of the lobe.
I see you are getting only 263* duration on a advertised 268* cam. I see only 2 explenations for this. Either the cam is incorrectly ground or your measurement is incorrect. To late now to do a run-out of the cam lobes while in a pair of V-blocks. Unless you want to remove the cam again. I really think if you are this concerned you should slow down and pick up a solid lifter some where. But the other hand says your not going to race NASCAR with this motor and since you nailed #1 TDC you could just use the mfr ICL on your degree wheel and call it done - as countless other have done.. BTW you should see somewhat an indication of max lift on your dial indicator when the degree wheel passes ICL. Check it out.
Good luck and don't pull your hair out over this issue.
To Cam Degreeing Question
Old Oct 29, 2017 | 03:26 AM
corvette_maniac
I agree. And BTW ... those numbers that I listed today were with a solid lifter. This thing is ground 5° shy on the .006 duration which was what was throwing me off. I'm going to retard the crank 4° which should get me much closer to the cam card's ICL of 106. If the duration was indeed 268 my ICL would be dead on right now. That should put me at 107.5. Like you said .. I'm not racing on the NASCAR circuit with this 400.
Old Oct 29, 2017 | 08:38 PM
Neil B's Avatar
Neil B
Using the XE268 specs (224/230@.050 110 LS 106 ICL), I came up with the following valve events @.050 using the Wallace Racing calculator:
IVO is 6.0 ° BTDC ( - indicates ATDC)
IVC is 38.0 ° ABDC
EVO is 49.0 ° BBDC
EVC is 1.0 ° ATDC ( - indicates BTDC)
Overlap is 7 °
If it were me, I would start by using the intake centerline method and then once the cam is on 106 ICL, I would then check the valve events @.050. I would shoot to get the centerline and the intake valve closing as close as possible to spec. For an asymmetric cam, getting the IVC event correct is probably more important than the intake centerline.
Old Oct 29, 2017 | 09:53 PM
corvette_maniac
IVC is 38.0 ° ABDC
EVO is 49.0 ° BBDC
Overlap is 7 °
This cam really more resembles an xe-262. Right now my ICL is sitting at 100 and that's pulling measurement down each side of the lobe .050, .100 and .200 which indicates to me that the lobe is symmetrical. My confusion came from the fact that I had assumed that the duration was going to be what I paid for. If I degree this thing IVO at 25° BTDC @ .006 I'll bet dollars to doughnuts the ICL will be right on 106.
I actually had thought that the cam was a tad small for my 9:1 400 4 speed/3.08 only to find that it's even smaller. I am tempted to change it at this point ... after all ... I'm already there ... only have to pull the radiator.
