plug wires...??? recomendations...???
Old Oct 10, 2002 | 01:53 AM
Oldguard 7's Avatar
Oldguard 7
Default Re: plug wires...??? recomendations...??? (SIGNGUY)
Stick with OEM wires if you are using a stock distrubutor.
Old Oct 10, 2002 | 03:57 AM
Titanium Rat's Avatar
Titanium Rat
Default Re: plug wires...??? recomendations...??? (Oldguard 7)
Delphis,,, kind of expensive but well worth it,,,,,,my brother brought some home from the Winston Cup team he works at,,,,,,thick wires, plus they have a protective sleeve, around them,,,,,,very high quality!!!! :yesnod:
Old Oct 10, 2002 | 11:47 PM
gdh's Avatar
gdh
Default Re: plug wires...??? recomendations...??? (Titanium Rat)
Where can you buy Delphi wires, seems that you have to be a large racing corp. to buy from them. Also any suggestions as to where to buy Magnecor in Canada?
[Modified by gdh, 10:50 PM 10/10/2002]
Old Oct 11, 2002 | 01:19 AM
Chris69's Avatar
Chris69
Default Re: plug wires...??? recomendations...??? (427V8)
I disagree about Taylors, they're cheap junk.
Get MSD or MagnaCore
What's the problem with the Taylors?
I went to the Magnacore site and they have lots of tech info to resolve questions such as electrical resistance, etc.
Old Oct 11, 2002 | 07:28 PM
OkeeGuy's Avatar
OkeeGuy
what about straight plug boot or 90* angle?
i will run headers so which do i want?
also...universal fit or custom fit?
which is best for a small block with headers? i like the idea of making my own lengths but i dont like the idea of crappy "homemade" ends...
do the custom fit ones give you the proper lengths to route them appropriately thru looms etc?
Old Oct 13, 2002 | 05:38 PM
jackson's Avatar
jackson
i will run headers so which do i want? also...universal fit or custom fit?
You'll use 90 degree sp boots on virtually any sbc... regardless whether factory or aftermarket exhaust. The custom fit (for your year, make, model) will USUALLY fit OE loom configuration & routing just fine ... BUT if you deviate from OE loom config then you'll be better off with universal fit (you cut to length & you terminate at cap).
Take a look at successful circle track motors ... most don't have looms/dividers. Typical is sleeved Moroso wires ... 5&7 and 6&8 drop from dist & loop under headers ... 1&3 and 2&4 lay right on top of intake and drop over front of heads ... then loop back under headers ... no looms, no dividers. Just hi-grade SLEEVED wires driven by MSD box & coil ... or a chevy HEI in lower classes. No problems either way.
Most major sp wire brands have MANY different grades & designs. In the simplest terms there are kinda cheezy Accel wire paks and beefy, VERY GOOD Accel wire paks. I like universal fit Accel 8.8 mm 300+ ferrospiral Race Wires (8.8 racewires have 4-digit pn beginning w/ 7). Moroso Ultra 40 is also beefy design ... big$. Any MSD & higher end Crane, Mallory & Taylor are also well-made. I work with a lotta big$ circle track stuff ... at the most, Magnacor & Nology may be an outlier on the radar screen.
