LED flasher questions
Old Nov 21, 2017 | 02:17 PM
mobird's Avatar
mobird
Default LED flasher questions
Hey everyone. I'm working on installing some LED tail lights in my 79. I know from doing some reading that my turn signals won't work because the LEDs have a lower power draw (too low to trigger the stock flasher).
I found an electronic flasher I can use at a local auto parts store, however I haven't changed my front or side marker turn signals to LED yet. Will the electronic flasher work with only the taillights being led and the front being incandescent? Or do I need to convert ALL the turn signals to incandescent first?
Old Nov 21, 2017 | 04:26 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It should, as long as the electronic flasher and handle the draw of the 12 volt lamps. I don't know the rating on the flasher you purchased, but the flasher only controls the voltage interruption to the lamps. It's still 12 volts going to all the lamps.
Willcox
Old Nov 21, 2017 | 09:50 PM
Bikespace's Avatar
Bikespace
I just left this comment in another thread.
I used this flasher:
http://www.jegs.com/i/JEGS-Performan...11107/10002/-1
Be sure to get the reversing base. I needed it in my wife's '79. I tried ordering it from a Corvette vendor, and it did NOT come with the base.
It works with all LEDs, or a mix of LED and incandescent, or all incandescent. You can't lose! You do need to supply a ground to make it work, though.
To LED flasher questions
