Checking catalytic converter
Old Nov 27, 2017 | 08:17 PM
Wrecked82's Avatar
Wrecked82
Default Checking catalytic converter
This is nothing more than a simple question. Have no thought that my converter is not functioning properly. But, if a cat were starting to become clogged, would not the inlet portion be hotter than the outlet side ant the inlet portion hotter than the input pipe. Using a laser light tester. Just wondering.
Old Nov 27, 2017 | 08:21 PM
Wrecked82's Avatar
Wrecked82
Maybe answered my own question. Found below via google
"Still, you can test your catalytic converter efficiency using a suitable kitchen thermometer, or better yet, an infrared thermometer like this one (recommended).
Start the engine and let it idle for about 20 minutes to bring it up to operating temperature. Or take your car to the highway and then come back home.
Park your car on a flat surface, set your transmission to Park (automatic) or Neutral (manual).
If you don't have easy access to the front or rear of the catalytic converter, raise your vehicle using a floor jack and safely support it on jack stands.
Take a temperature reading of the inlet pipe that connects to the front of the catalytic converter, and take a note of the reading.
Then, take a temperature reading of the outlet pipe that connects to the rear of the catalytic converter and take a note of the reading.
If the catalyst has stopped working, the front temperature will be about the same as or higher than the rear temperature.
In a good catalytic converter, the rear of the converter will be 20 F degrees or more hotter than the front."
Old Nov 28, 2017 | 01:48 PM
Wrecked82's Avatar
Wrecked82
Tested mine with my trusty laser temp guage. Rear is clearly about 70* hotter than inlet. So, cat must be working OK even without the smog junk. Car running really smoothly now.
Old Nov 28, 2017 | 07:31 PM
Duane4238's Avatar
Duane4238
You do know that people who talk to themselves aren't crazy, but those who answer themselves are? Just kidding! Glad you answered your question. It's fun when you figure something out.
Duane
Old Nov 28, 2017 | 07:48 PM
Big2Bird's Avatar
Big2Bird
If you want 10hp more for cheap, and better emissions, get a Magnaflow cat.
Old Nov 28, 2017 | 08:39 PM
Wrecked82's Avatar
Wrecked82
Think mine is a Catco. Replaced it years ago on company's nickel.
Old Nov 28, 2017 | 08:54 PM
Wrecked82's Avatar
Wrecked82
I recently read that someone was having a Magnaflow cat installed and noticed the box said "made by Catco" and even had the same part number as the Catco box sitting nearby. Who knows.
Old Nov 28, 2017 | 10:26 PM
Big2Bird's Avatar
Big2Bird
Not a chance. Magnaflow factory is in So. Cal.
I have been there with Richard Waitas. They make all their own cats. mufflers, and even the pipes from strip steel.
Its rolled and formed on site.
I even have the test "cat back" prototype on my car.
Old Nov 30, 2017 | 06:28 PM
Wrecked82's Avatar
Wrecked82
Your most certainly correct. Only reporting what I read in another recent post on another site. A lot of product gets rebranded but part numbers stay the same. OP of that post probably wrong. Take your word for it.
To Checking catalytic converter
