Crankshaft pulley missing bolt
I have been lately chasing down a problem with vibration in my engine starting around 3k rpm.
The half shafts are quite solid as long as u-joint at the rear end, so I discarded that area.
Since it was more notorious at the shifter, my car is 4 speed manual, I focused myself in the engine and gearbox area. Gearbox shift pretty well but it has couple leaking places, other than that seems to be OK though.
When reving the engine with engaged clutch is more notorious, but with no clutch engaged whatsoever I feel some vibs as well...however not that many.
So, I paid attention on the harmonic balancer area and I have seen what I think is a missing bolt on the crankshaft pulley, otherwise I don’t think the pulley can be balanced with just 2 of them.
The pulley’s hole seems to be slightly misaligned with the thread so I don’t think I can bolt nothing this way.
My questions are, can I loose the existing 2 bolts, along with the main one in the center in order to rotate a bit the pulley and get all 3 holes fully aligned? What kind of bolts should be installed in that place? I’m considering to even replace all 3 with new ones in order to secure they are the same ones in all three locations.
Any information about how to do it anbolts info is more than welcome.
I guess that there is no problem on using impact gun to loose the bolts, actually would be easier I think.
New bolts just ordered along with washer lock, they are 3/8"-24 0.75 grade 8.
Now is the moment to take advantage and paint the pulley.
I wish this is the reason why I am having those vibes, it will be an easy fix.
OP, I might look at getting a new pulley. There is a possibility that yours could be bent due to running with uneven torque. If you are not looking to keep it stock the aluminum ones run very well (and look good too).
Here's the original pulley, harmonic balancer, and bolts on my 71.
You can see that even originally only 3 of the holes lined up with the holes in the balancer.
You might want to remove the bolts and take a close look at the balancer too in order to know for sure if a new pulley is needed, or just one more bolt.
Regards,
Alan
Based on this picture they seem 16 thread to me. Let see if I have time and take them out to confirm
However, these ones are thread 24, and they advertised for chevy small block.....SS ones though
https://www.ebay.com/itm/ARP-430-680...RYjV9X&vxp=mtr
You got both balancer bolts wrong. Real big surprise.
3/8"-24 and 7/16"-20
Bolts installed are:
3/8"-24x1"1/4... don't know why that long because they are supposed to be 3/4" long... was Bubba playing around? I think so, see the pictures with the washers, one per bolt
On the other hand the center bolt is 7/16"-20x2"1/4 and as you can see the thread is damaged, I just hope the crankskaft thread is OK, a new bolt was ordered.
And finally we have the pulley or I would have to say pulleys, I didn't know that they can be split. The holes are not elongated, there was only crap and dry mud on the them, they will be cleaned up and painted.
Do you guys have the info about the torque for each bolt?
BTW, the harmonic balancer looks ok with that central rubber belt in good shape, there was no play, dents, cracks or anything to be worry about.
Since it was more notorious at the shifter, my car is 4 speed manual, I focused myself in the engine and gearbox area. Gearbox shift pretty well but it has couple leaking places, but seems to be OK though.
When reving the engine, with engaged clutch, is more notorious, but with no clutch engaged whatsoever I feel some vibs as well, but not that many.
The previous owner was an elder man and the car was not driven too much either during the last years, and if so in a quiet way as well, below 3k rpm you barely notice any vibes.
It’s funny, because at the beginning I though the vibes came from the Flex a lite fan, bolted directly to the water pump, so I installed electric fans, and right after I saw this missing bolt.
Other than that the can runs pretty well with no issues whatsoever.
I hope this finally fix the problem.
