Side pipe headers
Old Nov 29, 2017 | 05:36 PM
Sayfoo's Avatar
Sayfoo
Default Side pipe headers
The Hooker side pipe headers on my 69 BB have had it. 1 side rusted out last year and I had them repaired. I went on a 200 mi ride last weekend and the other side blew a hole. Real thin in numerous areas. So, rather than messing around and patching them, I think I'll buy new ones. I just need black painted steel. I don't need to go with Hookers, but I would like to get something that will work with my Hooker side pipes and mufflers which are in good shape.
So, any recommendations on current brand quality, price, etc.?
Mostly stock 427/390.
Old Nov 29, 2017 | 05:57 PM
flyeri's Avatar
flyeri
If I recall correctly the Doug's and Hooker headers are not the same length. The overall length is the same because one of the brands has slightly longer expanded section on the side tubes and longer collectors. Seems like one slides maybe 4" into the tube and the other is 4.5". If you mix brands one combination will be longer than it should and the other will be short.
Old Nov 29, 2017 | 06:28 PM
PainfullySlow's Avatar
PainfullySlow
^ exactly. The trouble will be to find an exact fit. My advice would be another set of hookers but get them ceramic coated. It will drastically improve the life of them.
Old Nov 30, 2017 | 08:11 PM
Sayfoo's Avatar
Sayfoo
The hookers really didn't fit the best, so I'm inclined to try the Dougs. Plus, the Dougs can be had for $600 delivered and the best I could come up with on the Hookers is $830.
I don't think that 4" vs 4.5" would make a major difference.
Anyone else know anything about this?
Old Dec 1, 2017 | 04:35 PM
3X2's Avatar
3X2
I'd get asset of Stahl headers, now made by ACP.
Old Dec 1, 2017 | 08:19 PM
Sayfoo's Avatar
Sayfoo
Looks like they only make small block for 69's
Old Dec 1, 2017 | 11:48 PM
wabco40's Avatar
wabco40
I had Hooker headers and side pipes however the headers didn’t even come close to fitting. I ended up using Doug’s headers and the Hooker side pipes. The fit was good.
The headers where originally metallic ceramic and side pipes stainless. I had them both done in black ceramic.
Old Dec 2, 2017 | 07:09 AM
69ttop502's Avatar
69ttop502
X2, these are the best and make more hp than the Hookers. Still use a 4 inch sidetube but the collectors are under the car. More optimal length primaries.
Old Dec 2, 2017 | 10:42 AM
3X2's Avatar
3X2
They make them for big blocks also. They had them on display at Corvette Carlisle.
Old Dec 2, 2017 | 10:45 AM
3X2's Avatar
3X2
Also available in 2" primaries- better size for a L36 than the 2 1/8" Hookers. Here's a picture,
Old Dec 2, 2017 | 12:51 PM
Sayfoo's Avatar
Sayfoo
[QUOTE=wabco40;1596088635]I had Hooker headers and side pipes however the headers didn’t even come close to fitting. I ended up using Doug’s headers and the Hooker side pipes. The fit was good.
I ordered the Doug's last night. Will be here in about a week.
Thanks all.
Old Apr 22, 2018 | 11:07 PM
El Mago's Avatar
El Mago
Who sells the X2's?
Old Apr 23, 2018 | 06:34 AM
69ttop502's Avatar
69ttop502
Sorry, by X2 meant I agreed with the other poster on the Stahl’s. They are a great header!
Old Apr 23, 2018 | 06:38 AM
3X2's Avatar
3X2
They are located in Harrisburg, Pa. Here is their website: http://acproducts.us/
Old Apr 23, 2018 | 01:03 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by El Mago
Who sells the X2's?
"X2" is computer shorthand for "times two", as in make that two opinions in agreement.
With respect to the Stahl (ACP) headers, they look like their collectors are significantly shorter than the Hooker of Dougs. Would the Hooker/Dougs sidetubes work with them??
EDIT...I just took a second look at the picture of the Stahl headers, as I was closing the thread, and this just struck me. The Stahl headers are designed to be a drag race header, so the 4" collectors running under the frame and out to the side of the car, won't be a problem. But I could see then creating a HUGE ground clearance issue, on a street driven car. That's why the Dougs/Hookers bring the 1 3/4" primaries out to the side, before joining them at the collector....
Old Apr 23, 2018 | 01:18 PM
3X2's Avatar
3X2
I had them on my 69 427 using Hooker 4" tailpipes before going back to the 67 side pipes. Yes, they are lower than the Hooker/Dougs/other brands with the collectors along the rocker. That said, the Stahl's make the most power. Be forewarned, the Stahl's may or may not fit with power steering and/or air conditioning.
To Side pipe headers
