found
Old Apr 23, 2018 | 12:12 PM
skrap's Avatar
skrap
1st Gear
Default found
I have a 69 vette has f c code 456 rear gm l88 hood and l88 fender flares the engine trans are missing
how can i identify
Old Apr 23, 2018 | 12:28 PM
HeadsU.P.'s Avatar
HeadsU.P.
VIN. Then click on "Tools" above to check it.
Old Apr 23, 2018 | 12:32 PM
MelWff's Avatar
MelWff
are you asking what was the original engine and transmission?
if it has a removal transmission cross member it was an automatic.
depending on the tachometer red line you can narrow the engine possibilities
assuming nobody changed the tachometer.
if it has a rear sway bar it could be a BB assuming again somebody didnt add the sway bar.
the type of radiator and presence or absence of an external expansion tank can give more clues.
Old Apr 23, 2018 | 02:02 PM
Alan 71's Avatar
Alan 71
Hi HU.P.,
For the 69 model year the VIN offers very little information about the car...
Whether the car is a coupe (37) or convertible (67).
The 69 build sequence number for the particular car. (700001 through 738762.)
Regards,
Alan
To found
