Baldwin Motion Hood?
The new motor is likely not going to fit under my L88 so I at the very least am going to have to step up to the high rise L88 hood. I really like the Baldwin Motion hood for something different. The other option would be to cut up my L88 hood and fabricate my own I suppose.
Any help is greatly appreciated.
https://www.ecklerscorvette.com/corv...1973-1976.html
But several vendors sell them. Look around.
Also, short hoods ended in 1972, not ‘74.
Guys made these before motion but motion made it famous,
I do not recall ever seeing a long one unless a cat built it,
One overpriced imo outfit sells a long for 73 to 82 cars lt1 bb hood on ebay you could add a 427 67 scoop on top of that,
Ecklers also has a hood called a stinger a long hood with 67 427 scoop,
Ecklers version of the short phase hood is different at the rear of the scoop compared to the motion phase hood,
Thank you for the information, looks like I will be fabricating one myself seeing as all the versions I have found are the short style hood. The only problem is that I don't know how well it will look without a wiper door.
GUSTO:
Yes that is the hood that I am looking at, only my car doesn't have a wiper door so I need a long style hood. I really like the look and functionality of it.
There was a member who sadly passed years ago he stacked a scoop on a l88 hood very sweet one of my all time favs,
For some reason i cant post pix
https://www.corvetteforum.com/forums...g-thunder.html
Also john silva offered that with his mako kit in the early 70s,
The mako was made to have a wiper door but some didnt like it or wanted the mako on a later car so he made his cover,
Its essentially the back of a long hood cut off and modded at the scoop area to mate with the hood one uses,
The sides where it meets the fenders are a little different 68 to 72, 73 to 79,
I just like short hoods on c3s, the wiper door is cantankerous cool to me but i would do just the cover to run a short hood,
I had this in the works before my falling out with mike,
derekderek
I don't think it will be that bad to mold together with the long style hood, with the hood shut it should look very similar to the original. I am going to do what 13Bats suggested and get a long style LT1 hood and the "Stinger" scoop and mold them together. Worst case scenario it was a fun project and if it doesn't work/look like I anticipate I still have an L88 to go with.
The13Bats:
I also like the short style hood/wiper door on the shark body. That would likely be the simpler route to go rather than molding the scoop to a hood. Was Rolling Thunder running a tunnel ram setup, the scoops looks to be sitting up a little higher (maybe it's just the angle of the photo)? It looks really sharp though.
I just don't think it would function correctly. I will go with a wiper cover.
