Did I get ripped ?????
Old Oct 10, 2002 | 03:37 PM
Blackened 79's Avatar
Blackened 79
Default Did I get ripped ?????
my mechanic is charging me about $600 (part alone) for a new radiator
for my '71....do you think this is out of line ???
:eek:
He's a vette guy (2 NCRS Certified 67 427's) so i hope he's being
up-front with me.
What do you think ? :confused:
Old Oct 10, 2002 | 03:41 PM
Tom454's Avatar
Tom454
Default Re: Did I get ripped ????? (Troublemaker 71)
Aluminum or brass radiator?
Old Oct 10, 2002 | 03:43 PM
Fevre's Avatar
Fevre
:eek:
up-front with me.
How do you think he can afford 2 67 427?
I think that is little high even for a NCRS. If you do not want a NCRS replacment rad you can get an alum one for under $200.
Old Oct 10, 2002 | 03:44 PM
Robert N's Avatar
Robert N
Default Re: Did I get ripped ????? (Tom454)
New radiator core, used my old tanks requiring additional work, stayed within NCRS guidelines- $331.25.
[Modified by Robert N, 12:45 PM 10/10/2002]
Old Oct 10, 2002 | 03:56 PM
Blackened 79
Default Re: Did I get ripped ????? (Robert N)
BRASS...THE ORIGINAL WAS NOT REPAIRABLE.
Old Oct 10, 2002 | 04:00 PM
Fevre's Avatar
Fevre
Here, make your own decision:
http://store.summitracing.com/partde...DDDC0D14DA994%
Old Oct 10, 2002 | 04:10 PM
Fevre's Avatar
Fevre
Default Re: Did I get ripped ????? (Fevre)
The dimensions seem wrong to me on that one: 25 x 17, here is what I have and it is a direct fit:
http://store.summitracing.com/partdetail.asp?part=31297
Your car had an expension tank so that might be a consideration but still think $600 is too high for a brass rad.
sb69coupe's Avatar
sb69coupe
If he's getting you the proper correct radiator for your car, it's not out of line. See:
http://www.dewitts.com/pages/productdetail.asp?ProdID=2
Old Oct 10, 2002 | 04:33 PM
ericshaw's Avatar
ericshaw
For that price it ought to be solid gold
Old Oct 10, 2002 | 06:36 PM
Paul L's Avatar
Paul L
Why not get it re-cored for less than $200?
Old Oct 11, 2002 | 12:49 AM
PRNDL's Avatar
PRNDL
Default Re: Did I get ripped ????? (paul79)
you guys are comparing apples to bowling *****. If you check the Zip website, you will see that they sell reproduction brass/copper radiators for $299. They also sell reproduction aluminum radiators for $779. Your mechanic is taking the customary 100% markup, except he probably pays less than $299. MJ
BTW, where is your mechanic? always good to know where to find a vette expert, even if he is a little pricey! :)
[Modified by MNJack, 11:53 PM 10/10/2002]
Old Oct 11, 2002 | 01:15 AM
L48Shark's Avatar
L48Shark
From: If you can read this, thank a teacher. If it is in English, thank a veteran.
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Did I get ripped ????? (MNJack)
Check the phone book under Dover... Ben Dover. :jester
Old Oct 11, 2002 | 01:29 AM
DMONSVETTE's Avatar
DMONSVETTE
Default Re: Did I get ripped ????? (L48Shark)
You sure it's for a brass one because Mid America Catalog shows that brass
ones START at $299. And reproduction aluminum ones are around $799.
:confused:
To Did I get ripped ?????
