Replacing rear adjustable struts question
Old Dec 14, 2017 | 03:27 PM
Ybnormal's Avatar
Ybnormal
Default Replacing rear adjustable struts question
Question is do I really need to release the composite spring from the trailing arms to accomplish this or can I leave it attached?
Thanks,
Steve
Old Dec 14, 2017 | 03:50 PM
Neil B's Avatar
Neil B
Thanks,
Steve
If the rear is raised and the composite spring is fully relaxed where the spring bolts have no tension on them, then I would say no. I'd probably 'get them out of the way' simply because they are so quick and easy to remove.
Old Dec 14, 2017 | 04:02 PM
Ybnormal's Avatar
Ybnormal
Thanks Neil
Well the rear is up but there is still tension on it and I was concerned on the force on the yoke clips inside the diff. I think you have a good point to get them out of the way but then I need to get them up out of the way to clear the inner strut bolts for removal I guess just remove the whole spring assembly would be best.....I'll just drink a beer and think about it some more
Thanks,
YBnormal....drive a vette
Old Dec 14, 2017 | 04:55 PM
Neil B's Avatar
Neil B
Thanks Neil
Thanks,
The 2 spring bolts at the end take less than 5 minutes to remove. Use a jack to take any tension off the spring before you remove the bolt. The whole spring can be removed in a matter of a few minutes as well. You aren't going to hurt the c-clips in the diff. The diff yolk acts as the upper control arm pivot anyway.
Old Dec 14, 2017 | 08:58 PM
Big2Bird's Avatar
Big2Bird
Thanks,
Steve
No. I have changed them without doing that. If the tires are on the ground or on blocks, it won't move a bit.
To Replacing rear adjustable struts question
