need suspension help
Old Dec 14, 2017 | 08:11 PM
jnew18's Avatar
jnew18
Default need suspension help
Hey guys,
I lowered the rear of my '79 with 10" bolts and would like to go lower. Is there any spring that would improve handling and lower the car more as well? i'd like to go another 3 or 4" down.
Old Dec 15, 2017 | 01:06 AM
ignatz's Avatar
ignatz
I don't have any lowering suggestions for you, but I do have a word of caution, you need to keep the end of that spring away from your tire.
Old Dec 15, 2017 | 03:03 AM
OldCarBum's Avatar
OldCarBum
And the end of the spring bolts above the lower lip of the rim. If you lowered the rear with 10 inch bolts and still believe you have another 3-4 inches, there could be an issue with your setup. Solving a possible problem could bring the rear end down where it should be.
Post some photos of your setup and let's see what is going on.
Old Dec 15, 2017 | 08:11 AM
Gordonm's Avatar
Gordonm
You have some other issues if you already have 10 inch bolts and need another 3 to 4 inches. Even a stock ride height C3 can barely go down 3 or 4 inches. Mine is down about 1.5 inches and that is about as low as you would want to go on the street. Picture of your setup would be helpful.
Old Dec 15, 2017 | 09:00 AM
Alan 71's Avatar
Alan 71
Hi j,
Which of your cars is this question about; the car you swapped the 725 hp LS engine into, or the car with the 327 engine?
Regards,
Alan
Old Dec 15, 2017 | 05:13 PM
jnew18's Avatar
jnew18
I shortened the rear spring and have plenty of clearance between the tires and spring. I'd love to go to a different spring that wold give better handling and also lower it some more. I'm not worried about ride quality.
here are some pictures of what i have ATM. I'm not sure if its stock or not.
It is a 79 with a 327.
Old Dec 15, 2017 | 05:57 PM
BLUE1972's Avatar
BLUE1972
My thought is COIL OVERS - totally adjustable..
Old Dec 15, 2017 | 06:05 PM
redvetracr's Avatar
redvetracr
a factory 7 leaf is stiffer than what you have, a 5 leaf Daytona rear is even stiffer but might be too stiff for the street...
Old Dec 15, 2017 | 06:15 PM
jnew18's Avatar
jnew18
I'd love to go coil overs if i had the funds, but alas i do not. Would a fiberglass spring do anything to lower and improve handling as well as lose weight?
Old Dec 15, 2017 | 06:31 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
A fiberglass spring, in my opinion, would most definitely be an improvement. I had good results with a VB&P rear spring.
HOWEVER, looking at the picture you posted, it looks like there's only a couple of inches between the ground and your exhaust pipes NOW. How are you going to lower it 3-4"??
Old Dec 15, 2017 | 07:39 PM
OldCarBum's Avatar
OldCarBum
In your picture it appears the spring bolts and even the ends of the springs are lower than the bottom lip of your wheel. if you had a flat or blowout this could cause catastrophic damage to you, your car and possibly anyone near you on the road. If you want your car lowered, do it safely by replacing your spring.
Old Dec 15, 2017 | 07:46 PM
jnew18's Avatar
jnew18
thanks for the input, guys. The pictures are sort of deceiving. I've got about 2.5" clearance on each end of the spring. I'm painting the car ATM and will be going to side pipes so wont have to worry about under the spring.
What spring would give the best handling? are there special shocks needed for a composite spring?
Old Dec 15, 2017 | 08:58 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Word of caution about going too much lower. If the inner u-joints of the half shafts are below the outer u-joints, this will adversely affect handling because the rear suspension bump-steer will increase. You really want the inner joints to be at least 1/2" higher than the outer joints.
If you want to lower the car 3-4", you should probably consider raising the rear differential relative to the rest of the frame.
Old Dec 15, 2017 | 09:25 PM
buns's Avatar
buns
My neck was getting sore from twisting it, so I fixed the pic.
Old Dec 16, 2017 | 12:49 PM
ignatz's Avatar
ignatz
If you reduced the fiberglass spring's spacers, the differential MIGHT sit a little lower on the spring. I'm not really sure, I would need to see what's in the original kit. Picture of my installation shows the spring is pretty much right next to the differential. I do love the handling improvement however, so just on that basis it is worth doing.
What are you after anyway? Maybe post a picture of the car so we can see what's bothering you?
Old Dec 17, 2017 | 12:11 PM
OldCarBum's Avatar
OldCarBum
In your picture, your half shafts are about an inch higher at the differential than at the trailing arms. With 10 inch spring bolts already installed, I think you have something wrong in your current setup that needs corrected before you compound the problem trying to lower the car even more. I would suspect you have an incorrect spring in the rear. I'm no expert, this is just my opinion. Think safety first.
Old Dec 17, 2017 | 12:17 PM
Alan 71's Avatar
Alan 71
Hi jn,
When you shortened the longest (bottom) leaf you effectively raised the the amount of weight it takes to deflect the spring a given amount
Think about someone on a diving board.... the further a person walks out on the board the more it bends.
You cut the 'board' shorter so the person can't bend the board as much.
Shortening the spring raised the car..... if you had cut it even shorter the car would be sitting even higher.
Regards,
Alan
Old Dec 17, 2017 | 12:25 PM
Kid Vette's Avatar
Kid Vette
A VB&P composite spring will improve your handling and give you the correct ride height with 8" bolts. What rating of spring you go with depends on your driving habits. They'll shorten the spring for you as well if needed.
To need suspension help
