Rotating assemblies
Old Dec 20, 2017 | 08:36 AM
Indiancreek's Avatar
Indiancreek
For a while Eagle sold a 10/10 crank that had been turned 0.010/ 0.010. Called it their lightened crank. What reality they were machining them in the US to align the rods and mains. What can't be explained is how much lighter the crank was by turning it 0.010/0.010. Since it then needs more bearing to fill that space, wiping out any weight savings from the turning. The biggest problem I have with the import engine parts id the metallurgy in the metal refining processes. I do gun machining for some folks in the machining area of my shop. I have come across metals in imported firearm parts that show inferior quality in things such as sears and slides on several occasions. Some stainless parts which have carbon steel contamination which leads to rusting that often can't be machined out. One slide in particular had three waves diagonally that I was unable to machine out. The rockwell test shows that the three waves were a different rockwell than the rest of the slide. So I suspect that if their quality in the metal produced for their firearm industry is questionable why wouldn't the metal in their engine parts be any different. SO back to the question at hand, for a driver part time racer, and in some cases a full time racer I guess they are ok to use as many do. It again depends on the budget and the use. Often time when a bottom end comes in and it has compressed it's last bit of air, it is difficult or impossible to determine the cause of it's destruction. So really the bottom end and often the top end is only as strong as the weakest part. Many builders have been accused of being less then good from the failure of a poor part. In the end it's a balance between the cash flow and good enough. Like has been said, there have been plenty 427/425 and 396/375 muscle cars running oem parts that raced their entire lives. I personally would use an oem forged crank over an import. The oem rods are forged I beams. I have one I keep laying in the shop for talking points that is bent probably 35 degrees and never failed. A large bolt oem rod will hold a lot of horse power.
Old Dec 20, 2017 | 09:34 AM
rklessdriver's Avatar
rklessdriver
SCAT makes decent stuff for the money. I have built a lot of street engines with SCAT cranks and rods. Never a problem.
Since you are building a 496 I would direct you to buy the crankshaft with center counterweights. SCAT offers both 6 and 8 counterweight 4.250 stroke BBC cranks.... buy the 8 counterweight crank. It's a little more money but will well worth it.
Will
Old Dec 21, 2017 | 10:36 AM
bence13_33's Avatar
bence13_33
Jim]:
Originally Posted by 427Hotrod
Callie's is definitely good stuff. The "regular" Callie's cranks are the same forging on BBC. The price difference is the amount of machining and lightening that occurs. The raw forgings came from Japan last I heard. I've got one in my motor and it's held up well.
The Compstar line is the Chinese import versions to compete with SCAT, Eagle etc. Still good quality.
The machine work by Callie's is some of the best out there out of the box. They also do crank machining for Howards I believe.
I've got Oliver rods in my engine and they are incredible. I've heard through the grapevine there may be new owners and things might have changed recently but don't know for sure.
I've been to SCAT's machine center in CA and was given a tour by the owner. They do LOTS of the OEM high performance parts used in the best crate motors and higher end race parts. I ran SCAT rods in mine for years.....still have them. Nothing wrong with them...bearings always looked perfect...just changed to the Oliver's with ARP 625 bolts considering how I run the thing.
JIM
I'm not sure if this is correct but I thought I recalled something about the Comp Star stuff being imported from China but checked and finished here in the U.S. .
It's so bizarre how things change I recall over a decade ago when I was building my motor the SCAT (for some reason I always thought they were called CAT) stuff was what people would steer you away from and the Eagle stuff was the way to go. I have a set of SCAT 4340 rods in my 468 that held up nicely. Now SCAT is the preferred stock instead of the Eagle stuff.
Old Dec 21, 2017 | 12:30 PM
OldCarBum's Avatar
OldCarBum
The shop helping me has been building motors for over 50 years. They recommended SCAT over Eagle because as stated above the Eagles are manufactured and machined in China. SCAT cranks are manufactured in China but all the machining is done here in the USA. They told me that Callies manufactures high end cranks and their quality is much better but at a much higher cost. They did say that Callies also sells less expensive cranks which are China made and he did not recommend those at all. They said that unless I'll be running over 1000 hp and drag racing, the SCAT forged cranks are more than acceptable for hp street use.
Old Dec 21, 2017 | 03:31 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Originally Posted by bence13_33
Jim]:
That's what I said. Compstar is Chinese but still good quality in the mid priced stuffCAT brand was junk. SCAT brand is good. Jim.
Old Dec 22, 2017 | 01:10 AM
TCracingCA's Avatar
TCracingCA
Crower or HTC
Old Dec 22, 2017 | 01:52 AM
68post's Avatar
68post
So where does Ohio Crankshaft's offering fall within these other budget cranks ?? And just where do they come from ??
