Scanner recommendation
Dec 22, 2017 | 07:16 PM
Hello! Newbie here. I please need suggestions for a scanner for my 82.
Thanks, Mark
Dec 23, 2017 | 11:00 AM
there are several .but the easy one to find is at the pawn shops . the old snapon red brick.
https://www.bing.com/images/search?q...nner&FORM=IGRE also check craigslist.make sure you have the gm connector.
Dec 23, 2017 | 11:05 AM
make or buy a cable from laptop to car.then use.this free download.
http://winaldl.joby.se/
Dec 23, 2017 | 04:12 PM
How much more info can be viewed from a scanner vs just reading the the cel light flashes?
Just curious....
Dec 23, 2017 | 06:26 PM
Quote:
Originally Posted by
terry82
thanks again!
Dec 23, 2017 | 06:32 PM
mikem350
Just curious....
Oxy sensor voltage, throttle position voltage,egr function, a few others. That's on an 81. I am sure 82 has more.
Dec 23, 2017 | 07:15 PM
theres a difference between a code reader and a scanner.code reader tells you the fault .a scanner can show you in real time what info the sensors are sending the computer.iac,map, rpm,tps,o2,and knock count . if you can see if the readings are out of spec ,,,,well theres your problem.
Dec 23, 2017 | 08:38 PM
St. Jude Donor '22
Big2Bird
The list shows 82.
No 81.
Does the 82 program work on 81?
Dec 24, 2017 | 12:31 PM
the winaldl program is for cross-fire 1982-1984.parts of it may work for the 1981,,, don t know .
Dec 24, 2017 | 02:09 PM
St. Jude Donor '22
terry82
Tend too agree it should give info.
But I have been wrong
Dec 25, 2017 | 10:38 PM
Has anyone tried an OBDI to OBDII adapter? I've got a nice OBDII cable I used with my old Audi, and it'd be nice to just have to download software and buy the adapter...
