1981 with 383 stroker, vacuum issue
Old Jan 5, 2018 | 06:58 PM
caryb78's Avatar
caryb78
Default 1981 with 383 stroker, vacuum issue
Because this engine is running a Holley Demon carb it blocks off the main vacuum port at the rear of the intake. SO a electric vacuum pump was added which the bubba who installed it screwed up the wiring and it does not work. I can fix the wiring but is there any other options for a vacuum source from the manifold?
Old Jan 5, 2018 | 08:14 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
get a better manifold or drill it
Old Jan 5, 2018 | 08:42 PM
HeadsU.P.'s Avatar
HeadsU.P.
Go to Ebay and in the motors catagory, type in the search box:
Low Profile Vacuum fittings.
I have the same issues. There are a couple fittings on there that look real promising. One has a photo of a Demon carb clearing the fitting. I believe you will need a 3/8 NPT. Then you can decide if you want 1,2, or 3 ports off of that.
To 1981 with 383 stroker, vacuum issue
