Cap and Rotor life?
Old Jan 14, 2018 | 10:18 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default Cap and Rotor life?
How often do the cap & rotor need to be changed on a '77 with HEI, all is stock?
Old Jan 14, 2018 | 11:15 PM
Big2Bird's Avatar
Big2Bird
50k miles is reasonable.
Truith is, i have run them till it misses.
Old Jan 14, 2018 | 11:17 PM
lars's Avatar
lars
The HEI system was designed to reduce maintenance and increase service intervals. The HEI components will easily run 50,000 between cap/rotor replacements, and I've run them as much as 100,000 before getting misfire and issues (I put 500,000 miles on an HEI-system Vette that I used as a daily driver with no engine or trans rebuild or any other maintenance issues, replacing cap and rotor only when it started misfiring around 100K).
Lars
Old Jan 14, 2018 | 11:41 PM
Big2Bird's Avatar
Big2Bird
Lars
My son had an old Seville with over 100K miles. I checked the cap, and the cap was melted around the rotor contact, almost burnt thru, and the car ran fine. Not a clue it was burning up.
Old Jan 15, 2018 | 08:24 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Thanks guys!
Old Jan 15, 2018 | 08:51 PM
HeadsU.P.'s Avatar
HeadsU.P.
About once a yr, remove cap and wipe inside with clean, dry, paper towel only.
No cleaners, no WD40, no nothing.
Old Jan 15, 2018 | 09:06 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I have changed them more frequent than
50k.
I might be on my 4th in 85k.
I finally went to a brass electrode cap.
thing doesn't show the arc wear the alum one do.
cheap part anywho.
Old Jan 15, 2018 | 09:14 PM
lars's Avatar
lars
You were replacing HEI system components every 21,000 miles..?? That's crazy: That's the tune-up and service interval of the standard points-type systems. The whole design purpose of the HEI was that it would easily outlast points service interval by 100%. You must have been getting some exceptionally poor quality components - I've never seen HEI components fail after 21K, and I worked at the GM Training Center as an HEI Systems Instructor in the mid-70's - I had access to the failure and service records. There were occasional module failures, but never a cap or rotor failure in 21K. Never.
Lars
Old Jan 15, 2018 | 09:19 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
no failure.
just got tired of sanding the arc trail
off the inside of the cap.
like i said cheap part and just made me
happy to have it new.
never a running issue.
To Cap and Rotor life?
