PVC system catch can
Old Feb 6, 2018 | 07:20 PM
  #41
Ryan Menzies's Avatar
Ryan Menzies
Originally Posted by Kingtal0n
If you block the freshair inlet of crankcase, and pull suction via intake manifold to crankcase, it will pull on every oil seal into the engine and ruin them.
So if you want to run this on the fresh air inlet, the size of hole you need to drill is equal to the size necessary to pull 10-40" of Water on the crankcase during idle speed. Better to go a little too large than too small to account for buildup of sludge over the years so make it bigger than you think it needs to be.
On the other hand, you can put that on the intake manifold -> crankcase side to disable PCV for cruise and idle. It will make the oil quality worse faster, it will reduce ring seal, possibly lowering compression and reducing economy, but overall it may improve WOT horsepower 1% or something. Better to have it hooked up for those benefits, the cost is so small. So one again, drill a hole, but don't oversize this one too much. A smaller hole is probably smart, less than 3/8" probably to start with, smaller than the fresh air inlet for sure. See what the suction is like on the fresh air inlet (using a gauge, shooting for 10" to 40" of water usually) open up the hole till you see that suction present with the appropriate hole on the fresh air inlet balanced to that vacuum.
Gotcha - makes perfect sense. I was going to leave my breather in the intake side valve cover. However the "flow and volume"" would be the same as before. I thought the little fittings with Blue hose would be to restrict flow on the PCV side but having it on the intake valve cover makes sense regarding slightly more balanced system, i'm if thinking on the same page?
Cheers.
Old Feb 6, 2018 | 08:52 PM
  #42
v2racing's Avatar
v2racing
Cheers.
I'm not sure what they were thinking when they put the open and closed fittings and 1/2" hose in the kit. I used the 1/2" hose on the nipple on my Mopar breather and inserted the PCV valve in the other end. Go back and look at my photos in the original post.
Mike
Old Feb 6, 2018 | 08:55 PM
  #43
Ryan Menzies
Mike
I saw that's where you used the 1/2 hose which is logical but the fittings didn't make sense since all three parts were clamped together.
If I need to I'll drill the one fitting and put the assembly in series with the PCV line.
