Worn cam lobe... what would you do?
The only good(?) thing is that a good portion of the metal falls to the bottom of the oil pan and stays there. What stays suspended gets to the oil filter, the downside of that is it has to go thru the oil pump to get there and then some of the really fine stuff gets past the filter.
On a 1969 ‘vette, can the cam be replaced in the car or should one pull the engine ?
How does one flush the engine as mentioned above?
Excellent point. If I have it out, I know will want to drop the pan, inspect the bearings etc. Best not to go down that slope.
Officially, you need to loosen the oil pan, but you can get the front cover off by working it off the pins at the bottom, and leaning it forward as you pull up. IT will go back on if you trim the corners of the seal lip on the cover and use a couple of small punches to work it back down on the pan lip and onto the pins. Not fun, but it can be done. I used to do it all the time in my dealer tech days.
You'll probably want to swap the timing chain and gears too.
continue to wear flat?
tough call for me.
i had a factory one go flat. took a while and was hard for dealer to
find.
car pinged and stunkup the cat verter.
at the time, gm supposedly cheaped out of the blanks
and quite a few 81s lost lobes.
i wish i knew what the service replacement grind was.
so, with bent rod, and no measurement the cam may just last?
you say it runs good, steady vacuum, no noise.
luckily the pan is an easy thing to remove in car
and a leak free cam change is possible.
hard call for me.
I will have to order my parts from Summit or Jegs. Add 30% for shipping and taxes. So, it’s best to get it right the first time round.
30% is better than I thought.
If I bought a British car part here. easy double.
As far as metal in the motor, if you are worried or would just like Peace of Mind, drop the pan (unbolt the idler arm and let the center drag link droop down out of the way) and pull a main bearing cap and see what condition it is in, cause IMHO, if metal is in one, it's in all of them. If the bearing looks good, put in a new cam, lifters and springs, seal the motor up and have fun.
Easiest way I know to swap a cam is pull the hood, radiator (gotta be mean to it to get it out and back in, sometimes) drop the pan as mentioned , pull damper, timing cover, chain, etc..
I kind of tripped over the cliff this winter. I was just going to finish finding all the po mistakes and correct them, but now I've got some aluminum heads, bigger cam, headers, intake.........
A good service manual will be a tremendous help also.
Later, jw
Thank you for your invaluable feedback. Really.
There's an expression in French which roughly translates as: the night brings good counsel.
Having slept on this, I think the best course of action is to pull the engine. One reason is of course to be able to carefully swap out the cam, flush then engine and ensure a leak-free reassembly. The other reasons include:
- timing tab needs to be properly mounted. I may have to helicoil a bolt hole; it will be safer to do that with the engine out.
- There is an intake bolt missing front passenger side
- I have a power-brake conversion kit to install, it will be easier with the engine out.
- wiring I can clean up
- clean up and inspect the engine bay;
- possibly swap in a borgeson while I am at it. It probably will be much easier to do like this...
This evening I will pull the intake (an open plenum Torker first generation). I will pull and inspect the lifters individually. If they are fine - no biggie, I'll swap in a better intake... If they are not... I pull the engine.
I also need to determine what caused the cam lobe to wipe.
I will limit my work to cleaning up, a new cam with lifters and a new timing chain. I'd rather get this back on the road fast and save up for a the expense of a crate later on.
Im buying shorty headers from summit ( 130$)
Shipping is 110$ and tax was something around 50$ according to summits website. (On the plus side, I could buy a lot of other parts without upping the shipping cost. Maybe its time to buy my new intake and engine dress up kit etc 😅
Yes, there is a certain amount of in-elasticity when it comes to shipping. Smaller items can be expensive to ship where as additional bulk is not much more. Likely I'll be doing a Summit order soon; they have served me well over the years. Keep in touch? There might be a way to share/split shipping if that is cost-effective.
