I am perplexed on what should be a simple job. A while ago I changed out the U-joints in the driveshaft chasing a vibration at highway speeds. I remember at the time the ujoints seemed to tight. It seemed like the ujoint posts were pressing against the caps. It moved way to hard, but I put it back in anyway. Well it still vibrated.
One of my jobs this winter was to take the driveshaft down and have it balanced. When I got it down it was obvious there was something wrong with the joints. Both of them move very tight and they both had obvious notchiness. I pressed the ujoints out expecting a crushed needle bearing, but as soon as it was released, the bearings move smoothly. No crushed bearings. I am back to the Ujoint posts were pressed against the caps.
On the ends of the drive shaft is the lettering CAN and Spicer 021A and F2-28-179.
I measured the distance from the outside of the retainer ring groves and both sides of the drive shafts and they are 3.348in (or at least both are 3.34). I measured the old ujoint and it is 3.24in. the retainer rings are 0.058. So when I add two retainer rings (0.116) with the ujoint (3.24) the total length is 3.356 -- 8 thousands to large.
What am I doing wrong -- there does not seem to be any damage or bending to the Drive shaft
I don't know how you pressed out the old joint or installed the new one. But, it is quite common for someone using a press without stabilizing the yoke to bend the yoke ends a bit and put the new joint in a bind.
I would suggest that you just have the place balancing the driveshaft to check it out and/or correct any joint/assembly issue while they have it.
If the newly pressed joints were tight, a smack with a hammer to the yoke usualy freed them up. Sounds bubba (because it is) but thats what happend in a lot of cases.
yup
need to inspect the tightness and look at the caps in relation to the
grooves.
a little tapping to straighten the unit is a good thing/
I broke down and bought two Spicer 5-1310X U-joints and they pressed in perfectly -- like they were designed for it!.
They seem tight, but move back and forth very smoothly. The old set were very tight and very notchy.
Not sure where I got the last set from, I guess I could blame it on cheap chinese bearings.
I will let you know if the vibration goes away when the car gets back on the road, but that wont be till spring -- and a new radiator, new ball joints, bushings, front shocks, and a brake rebuild on one side. Been a busy winter to do list.
