Header gaskets
Old Jan 20, 2018 | 07:36 PM
bschuus's Avatar
bschuus
Default Header gaskets
I have a question. I just installed hooker headers and side pipes on my stock 1980/350 and of course the headers leak. I’m also using stage8 manifold bolts. I was wondering if anybody knows of a better gasket than what comes with the headers.
I’m still amazed how the stock manifolds had no gaskets and they didn’t leak!!
Old Jan 20, 2018 | 07:40 PM
jb78L-82's Avatar
jb78L-82
I always double up the gaskets on each side. I buy 2 sets of Felpro header gaskets, put red permatex between the 2 gaskets, clamp them and let them sit for a few hours to cure as one. Install. I have used this method on 3 sets of different headers, two of which the single gaskets would not seal completely and after the double gasket, have had no leaks for years now. I always use double gaskets now even on new headers like I put on my C3 1 year ago. Cheap insurance against leaks..............
Edit-I used Percys on a shorty header that was warped over time from the heat and it would NOT seal or solve the problem. The Felpro double gaskets did and now about 8 years on they are still on the engine on that car and not leaking.
Old Jan 20, 2018 | 07:48 PM
HeadsU.P.'s Avatar
HeadsU.P.
The sealing flange on some headers is anything but a flat surface sometimes. Nicks, scrapes, poor weld flashing and warpage. An old trick was to take a hacksaw blade and score the backside (towards the head) of the flange between the front cylinder exhaust port and the middle port. Then repeat between the middle and rear ports. DO NOT cut very deep. Just enough to allow the flange to flex some.
As far as gaskets, had excellent luck with Percys header gaskets. Soft aluminum layers seal very well because they conform to all the imperfections of the flange. I believe there are seven layers of aluminum per gasket. Around $35 at Summit. And you can use them over & over again.
Another tip is to start the two end bolts, slip gasket in, then install center bolts torquing all bolts from the center outwards.
Old Jan 20, 2018 | 07:52 PM
drwet's Avatar
drwet
I use SCE copper gaskets with my Hookers. Last time I removed the headers I could see soot tracks on the gaskets which tells me they were leaking a little, but until I saw that I couldn't tell they were leaking. At least that's better than any other gasket I have tried.
Old Jan 20, 2018 | 07:59 PM
HeadsU.P.'s Avatar
HeadsU.P.
Retorque three times a year with boxend wrench, just for peace of mind.
Old Jan 20, 2018 | 08:01 PM
bschuus's Avatar
bschuus
All great suggestions. Thanks!👍
Old Jan 20, 2018 | 08:07 PM
flyeri's Avatar
flyeri
I replaced mine recently with a Cometic gasket. I got it at O'Reilly. They have a black rubber like rough texture coating. I was not sure how well they would seal but they seem to work very well. I will have the headers off again soon and I will use them again.
Old Jan 20, 2018 | 09:23 PM
drwet's Avatar
drwet
Three times a year? I probably retorque them three times a month! Part of the problem I have is the bolts are very hard to get at, and some of them I can only get on with an open end wrench. I have the 3/8" bolts with the 7/16" heads but its still hard to get on a few of them. I have thought about looking for bolts with Allen heads but haven't actually tried that yet.
Old Jan 20, 2018 | 09:31 PM
croaker's Avatar
croaker
Percy's
Old Jan 20, 2018 | 09:41 PM
HeadsU.P.'s Avatar
HeadsU.P.
Try ARPs 12 pt specifically for headers. Stainless steel or black, 3/8 small head w/ built in washer.
Old Jan 21, 2018 | 12:16 AM
ddawson's Avatar
ddawson
Percy's and ARP stainless bolts with lock washers here.
Old Jan 21, 2018 | 06:16 AM
skids's Avatar
skids
I agree but they are also available in 5/16" wrench size.
Old Jan 21, 2018 | 08:46 AM
bschuus's Avatar
bschuus
Ok I’m sold on Percys but I’m looking at ARP bolts but the washers don’t look like they lock like the stage8 bolts I bought
Old Jan 21, 2018 | 09:23 AM
jb78L-82's Avatar
jb78L-82
Another thing that I discovered about the grade 8 bolts with the lock washers which are a royal pain to get on. I had them with one of the sets of shorty headers that warped and necessitated the double gasket trick from trying different gaskets until the double gasket trick solved the issue. I decided to try using the grade 8 bolts without the locking washers since I was taking the headers on an off so often with the trial and error method to solve the warpage leak. Surprise! that after 2 heat cylces of tightening the grade 8 bolts without the locking washers, the bolts stayed tight and I have not had to tighten them in years. Regular header bolts require tightening a few times every season on my other cars...............
Old Jan 21, 2018 | 09:31 AM
Rodnok1's Avatar
Rodnok1
I hope you checked them for flatness before installing.
The copper or aluminum gaskets that crush are the best, having headers since the 80's I've used just about every header gasket and never used a double.
The ARP header bolts are about the best optiong. I've used locking bolts of various types and the issue is usually can't fit half the damn locking parts between bolt and header.
Old Jan 21, 2018 | 09:44 AM
drwet's Avatar
drwet
I've looked at most of the locking systems for header bolts over the years but I can barely get a wrench on my bolts. ( I have the stainless ARP's.) Pretty sure there's no way I'd get all that hardware in there. Best option I've found is the copper gaskets and retorque regularly.
Old Jan 21, 2018 | 09:47 AM
jb78L-82's Avatar
jb78L-82
Like I said before, I had a pretty decent header flange warp issue on a pair of shorty headers and the Percy's gasket which I tried would not seal those headers...the double gasket did and are still on that car as well as my 78 with LTH that were new...was not taking any chances with the 78 C3 headers...no issues.
To Header gaskets
Old Jan 21, 2018 | 09:48 AM
HeadsU.P.'s Avatar
HeadsU.P.
Don't worry about "locking". Nobody is going to steal them. (old joke)
Some guys use anti-seize, some use LockTite on the bolts. But the main thing is to check on them once in a while. I have never (knock on wood) had a header bolt loosen.
Old Jan 21, 2018 | 09:51 AM
jb78L-82's Avatar
jb78L-82
Apparently the grade 8 stainless bolts stay tight with no locktite on my bolts...I was and still am pretty amazed years later now (and I have checked them) that they remain tight......
Old Jan 21, 2018 | 11:26 AM
Street Rat's Avatar
Street Rat
I use the FelPro 1444 gaskets, anti-seize (alum. heads), and 3/8" head arp bolts. Check the bolts frequently as they will loosen with the heat cycles. I tried the stage 8 bolts but couldn't get the retainers on without grinding them. Useless with my headers. My .02.
