1979 C3 Upper transmission cable.
How are you supposed to get the grommet over the fittings already pressed onto the cable?
Should have asked about the upper speedometer cable, there is no transmission cable.
Don't worry I will not post a question about the kanibbling pin as it is functioning fine.
1979 did not use the 'lock out cable' like previous year Corvettes and it does not run through the firewall.
There is no need for a firewall grommet due to the only two cables I am aware of are:
1.) The shifter cable that attaches to the shifter and goes through transmission tunnel area and not the firewall and it has its own special rubber seal made onto it and is held down by three screws.
2.) The kickdown cable. And it does not go through the firewall because it is on the outside of the transmission and does not need to go through the firewall.
DUB
I meant to say the upper speedometer cable not the transmission cable. Don't I feel like an idiot again.
My 1979 C3 has cruise control that I want to repair also.
I knew what I meant but my fingers got confused typing. LOL
DUB
And the grommet I am using has only ONE hole in it...becasue if my memory serves me correctly...there is METAL in this grommet so cutting it is out of the question.
DUB
