Which Headlight Bulbs Will Allow Fiber Optics to Function
this has the nipple for the connection
https://willcoxcorvette.com/corvette...low-beam-58-82
its a wagner 4000 lamp so if local store has it, ok
Received 2,878 Likes
Hi P,
When installing the new bulbs be aware that originally there was a little black plastic 'sleeve' that bridged the gap from the headlight to the electrical connector.
It's purpose was to insure that the connector gathered all the available light for the fiber optic cable.
There were 4 of them.
They've often been lost.
Regards,
Alan
The 'sleeve' in place.
Regards,
Alan
Received 3,220 Likes
If you are a little creative - you can make even a replaceable bulb type headlight work.
Bosch High Beam
Drill hole to fit fiberoptic - IIRC it was 1/8"
Fiberoptic plugs right in
Rubber dust/water shield holds it in place-
Bosch High Beam
Hi P,
Regards,
Alan
Regards,
Alan
strange the web site says Advance carries them
http://www.wagnerbrake.com/where-to-...all&country=US
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
