Head gasket
Old Jan 29, 2018 | 07:58 PM
jac1982's Avatar
jac1982
3rd Gear
Default Head gasket
Hi, guys and gals.
What is the best head gasket to use with alum. heads copper or steel? thanks
Old Jan 29, 2018 | 09:29 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Originally Posted by jac1982
Hi, guys and gals.
Copper ring like these. Steel ring can cause brinelling of aluminum heads. Make sure you get the right thickness for your engine.
https://www.summitracing.com/parts/f...iABEgIvefD_BwE
Tom
TimAT's Avatar
TimAT
I'm using Fel-Pro.. The blue composite ones.
Old Jan 30, 2018 | 06:47 AM
Dynra Rockets's Avatar
Dynra Rockets
"best" is subjective. I used the stock 1990-91 L98 GM MLS gasket when I installed my aluminum heads. No issues to date.
Old Jan 30, 2018 | 09:43 AM
HeadsU.P.'s Avatar
HeadsU.P.
I can tell you there is a reason some gaskets are $20 a pr and some are $50 each. I can't give you part numbers but my advice is stay on the expensive side. Too much work to have to do it twice.
Old Jan 30, 2018 | 10:47 AM
drwet's Avatar
drwet
Always had good luck with Fel Pro gaskets. You'll have to do some research to find the right part for your application. There is a special combustion ring for aluminum heads. Its called pre-compressed or something like that. You also have to get the right bore diameter.
Old Jan 30, 2018 | 11:42 AM
REELAV8R's Avatar
REELAV8R
This is the ones I have used with aluminum heads.
https://www.summitracing.com/parts/f...SABEgIfcPD_BwE
It's .015" thick so only really works with stock deck height. If your block has been decked they may be too thin.
Old Feb 1, 2018 | 11:16 AM
PainfullySlow's Avatar
PainfullySlow
Yep, these are what I am using on my stock deck 383 build with aluminum heads.
Old Feb 1, 2018 | 11:54 AM
jb78L-82's Avatar
jb78L-82
Felpro 1094 .015 inch with my AFR's...no decking was done on the block
Old Feb 1, 2018 | 07:43 PM
jac1982's Avatar
jac1982
3rd Gear
Thanks guys that felpro 1094 head gasket puts the quench at .041 , just about right. thanks again!
Old Feb 1, 2018 | 09:37 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I always use Cometic, they are pricey, but are great gaskets with aluminum heads.
Old Feb 1, 2018 | 09:50 PM
ddawson's Avatar
ddawson
I used this one on my BBC
Amazon Amazon
"Forged in the fires of high performance engines, Fel-Pro performance head gaskets are quite literally created to tame the fiery combustion chambers of up to 1,000 hp engines. Reinforced with KEVLAR® fiber and engineered to give you a perfect seal that can withstand combustion pressures of 1,500 to 3,000 psi, these gaskets are bred for high performance. They have a conformable anti-stick coating—and are constructed with pre-flattened copper or steel rings to make these gaskets easy to install, while also giving them the strength to tame your beastly power plant. Their anti-stick coating ensures easy removal and cleanup on frequent rebuilds, but they also aid in micro-sealing minor surface irregularities. When rebuilding your engine, use the parts you wish were in it to begin with. Put a set of these Fel-Pro performance head gaskets in that engine--not only to help it perform better today, but to make your next engine project that much easier."
Old Feb 1, 2018 | 10:28 PM
REELAV8R's Avatar
REELAV8R
https://www.amazon.com/Fel-Pro-1037-.../dp/B000CNNH7S
That would be a good gasket for a zero decked block.
Old Feb 5, 2018 | 10:04 PM
jac1982's Avatar
jac1982
3rd Gear
do you put gaskets on naked or do you spay them with copper paint, this may be old school? thanks
Old Feb 6, 2018 | 06:50 AM
Dynra Rockets
Follow the manufacturers instructions. Any modern head gaskets I have used has some sort of coating on them, even MLS, meaning you put them on dry. The only time I have ever used a spray was when I used a flat sheet copper gasket on a custom 4 cylinder 20+ years ago and when, in desperation, I had to reuse an original MLS gasket when no new ones were available (Taurus SHO V8).
R
Old Feb 6, 2018 | 11:37 AM
REELAV8R's Avatar
REELAV8R
I use the K&W copper coat gasket sealer.
My thinking is that the block surface may not be smooth enough to seal properly with just the gasket so this is kinda like insurance. It may not even be necessary but it's a lotta work to replace the head gaskets. I haven't had a leak yet on either aluminum head to cast iron block, and it's been about 6 years and 12000 miles.
Amazon Amazon
Old Feb 6, 2018 | 11:59 AM
HeadsU.P.'s Avatar
HeadsU.P.
If you're in the privacy of your own garage, clothing is optional. If in the driveway its frowned upon by neighbors.
To Head gasket
