Carburetor
Old Feb 4, 2018 | 08:15 PM
KiLLerDeathX's Avatar
KiLLerDeathX
6th Gear
Default [Solved] Carburetor
What would cause a motor to rev higher when the choke opens ??
Old Feb 4, 2018 | 08:39 PM
Duane4238's Avatar
Duane4238
Year? Engine? Carburetor? Information needed.
Duane
P.S. Go Philly!!
Old Feb 4, 2018 | 08:49 PM
KiLLerDeathX
6th Gear
350 Chevy 74 750 Holley stroked motor 383
Old Feb 4, 2018 | 08:54 PM
KiLLerDeathX
6th Gear
Duane
P.S. Go Philly!!
1974 stroker 350 , 383, Holley 850 I think either 780 or 850
Old Feb 4, 2018 | 09:08 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
barring a broken idle cam system
vacuum leak
edit
hmmm
broken choke pull off?
float bowl?
Old Feb 4, 2018 | 09:21 PM
KiLLerDeathX
6th Gear
Thanks for the info I don’t know how to check for either of those problems
I need to have it looked at by someone I guess.
Old Feb 5, 2018 | 12:11 AM
7T1vette's Avatar
7T1vette
Most likely cause is that the carb is running way rich at idle. When it opens, the A/F mixture is 'better', so it picks up RPM.
Old Feb 5, 2018 | 12:42 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
i assumed this was a new problem.
is this a new motor and are you tuning?
Old Feb 5, 2018 | 02:15 PM
MelWff's Avatar
MelWff
see your other post with the same question
https://www.corvetteforum.com/forums...arburetor.html
Old Feb 5, 2018 | 08:03 PM
Big2Bird's Avatar
Big2Bird
Because it is getting more air.
To Carburetor
