another distributor question.
Old Oct 13, 2002 | 11:09 PM
QuickVet's Avatar
QuickVet
Default another distributor question.
My rotor keeps eating away at my HEI cap. I dont get it. could the shaft on my distributor be bent or something. I actually find chipped of peices of plastic when i take the cap off, BIG PEICES too. Im may just buy a zz4 distributor but has anyone else seen this :confused: I can post pics if you cant vision what i am trying to explain.
Thanks for any advice. :smash:
Old Oct 13, 2002 | 11:14 PM
SharkAttack's Avatar
SharkAttack
Default Re: another distributor question. (QuickVet)
Your cap should only fit one way, so are the "chips" from the same area (e.g. cylinders 4-3-6) each time you replace the cap? That could indicate a bend.
Old Oct 14, 2002 | 08:23 PM
QuickVet's Avatar
QuickVet
Default Re: another distributor question. (SharkAttack)
ya i put the cap on the correct way. i just think there has to be something warped about my distributor. i have also replaced the rotor a few times and i dont think that is it. If you look in one of the caps you can see there are a few fins that come out a little this are being broken off all the way around :crazy:
To another distributor question.
