cigarette lighter makes engine miss
Old Feb 15, 2018 | 04:39 PM
mwm3006's Avatar
mwm3006
Default cigarette lighter makes engine miss
Pushed in my new cigarette lighter while driving down the road. Car started missing really bad. also heard heater blower come on. Limped car back to house. Afraid to push lighter in again. Any clue to what this would be. Thanks
Old Feb 15, 2018 | 04:51 PM
MelWff's Avatar
MelWff
How about some more details, did you install the lighter or someone did it for you?
When it was installed did someone not reconnect a ground wire in the console?
What is the reading on your volt meter or amp meter with and without the light engaged?
Old Feb 15, 2018 | 05:05 PM
mwm3006's Avatar
mwm3006
I installed it. Old one didn't work. It's been about a year ago. If I recall it just had the one wire that connected to the bottom of unit. Don't remember seeing any ground wire.
Old Feb 15, 2018 | 05:22 PM
Big2Bird's Avatar
Big2Bird
Without a good ground, the power thru the lighter took the path of least resistance.
My 81 has a ground wire to the light socket "barrel."
Old Feb 15, 2018 | 05:36 PM
mwm3006's Avatar
mwm3006
ok. thanks I'll check. Don't know why that would make engine start stumbling. Crazy
Old Feb 15, 2018 | 06:22 PM
lvmyvt76's Avatar
lvmyvt76
ground wire is black with a very large ring on the end(on a 76) that goes around the cylinder barrel of the lighter(have to unscrew the barrel to put on & off.) Allan we need pictures!!!!!!!
Old Feb 15, 2018 | 08:04 PM
Richard454's Avatar
Richard454
However it will also take ALL paths-
Did the lighter pop back out?
The cigarette lighter is a coil of metal- when you push it in- it shorts out the metal- till it glows red hot. When it heats up a bi-metal strip, it releases so a spring pops it back out. So it's basically a controlled short circuit.
Richard
Old Feb 16, 2018 | 07:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by lvmyvt76
...ground wire is black with a very large ring on the end...
That depends on model year. Early cars use a spade terminal ground to the underside of the console trim plate.
Old Feb 16, 2018 | 12:17 PM
MelWff's Avatar
MelWff
you didnt answer the question about your charging system, if the load from the lighter is sufficient to cause a miss I would check the output voltage of the alternator in addition to the possible ground.
Old Feb 16, 2018 | 02:15 PM
Tbone4432's Avatar
Tbone4432
Default cig. lighter
Your car is telling you not to smoke.
Old Feb 16, 2018 | 05:36 PM
derekderek's Avatar
derekderek
I was gonna say the same thing. Quit smoking. Or at least stop devaluing your car by making it suck up your second-hand smoke...
Old Feb 16, 2018 | 10:01 PM
Duane4238's Avatar
Duane4238
Yes, the spirits are speaking to you and telling you that you will soon have a miss, just like your engine, if you don't quit smoking.
Duane
Old Feb 17, 2018 | 06:38 AM
derekderek's Avatar
derekderek
most likely the hot wire to the lighter is on the ignition circuit and too light for the load. but it is probably just fine for charging cell phones...
Old Feb 17, 2018 | 07:57 AM
jimvette999's Avatar
jimvette999
I'm not a smoker, but if the guy wants to smoke, leave him alone. It's his car. He's already being told he can't smoke here, there, everywhere. It's supposed to be a free country.
Old Feb 17, 2018 | 08:08 AM
Grumpy 427's Avatar
Grumpy 427
Yes you cant miss the large ground ring when you took it apart. Unless its been taken apart before and wasn't there. Ether way don't beat yourself up over it.
Old Feb 17, 2018 | 06:47 PM
DUB's Avatar
DUB
This is correct if it is a 1977 to 1982 with the plastic shift/console plates.
If it is a Corvette with the metal shift plate...that large ground ring is not used and the ground is attached to the AC/heater controls in most cases.
DUB
Old Feb 18, 2018 | 09:16 AM
diehrd's Avatar
diehrd
Have you checked your ignition source supply ?
I wonder if someone feed the ignition off the lighter
To cigarette lighter makes engine miss
Old Feb 18, 2018 | 05:52 PM
DUB's Avatar
DUB
It appears that it is time to use an ohmmeter and checking circuits/wires.
DUB
Old Feb 20, 2018 | 11:17 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Maybe the ground ring was missing from the first lighter assembly...explaining why it didn't work in the first place
Old Feb 20, 2018 | 01:22 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
missing ground ring on Lighter.
No electronics work with a single wire connection.
all electronics require power +12volts, and ground.
you might get lucky and it work sort of, but not correctly.
