Slow wipers?
Old Feb 15, 2018 | 07:02 PM
flatop's Avatar
flatop
Default Slow wipers?
I replaced the wiper motor due to very slow wipers. Now I have slow and maybe a little faster wipers. Could something else be causing the speeds to be so lethargic?
Thanks for your input.
Old Feb 15, 2018 | 08:30 PM
Mooser's Avatar
Mooser
What year?????
Did the linkage move freely without the motor connected?
Could be a bad ground causing it to "find" it's own ground through the linkage arms or who knows
It might also be the switch but since it's working at all it's probably not the switch.
First and easiest test, use a jumper wire and ground the case of the wiper motor to something (alternator housing?) and try that.
If that does nothing, check voltage at the motor
Since you've switched motors it's possible, but unlikely it's the motor but you can test them sort of easily, check the wiper test videos by Wilcox
HIH
M
Old Feb 15, 2018 | 09:12 PM
lvmyvt76's Avatar
lvmyvt76
are you putting water on the windshield during testing???
Old Feb 16, 2018 | 11:09 AM
henrikse's Avatar
henrikse
If you have a meter take a voltage reading at the wiper motor with car running. You should get full battery voltage here. If not move your neg meter to a good ground (battery post -)
If no improvement then check fuse, fuse tabs and wire to wipers.
Old Feb 16, 2018 | 08:02 PM
flatop's Avatar
flatop
Originally Posted by Mooser
What year?????
HIH
M
Its a 77 and thanks for the advice. I will do some tests.
To Slow wipers?
