Header Torque
Old Mar 8, 2018 | 04:57 PM
joe1950's Avatar
joe1950
Default Header Torque
I finally got a set of headers for my 69 Vette 350 what's a good torque for the header bolts?
Old Mar 8, 2018 | 07:56 PM
HeadsU.P.'s Avatar
HeadsU.P.
Thats what you call a loaded question. You could be using 40 yr old rusty bolts or brand new ARPs black oxide bolts. And it depends on the heads, cast iron or aluminum. So, rough answer, around 25 ish working from the center bolts outwards.
You are not going to get a torque wrench in there anyway so just a pinch past snug.
The important thing here is to re-snug after a couple more heat cycles. And using a boxend wrench lessens the chance of snapping a bolt off as opposed to a ratchet.
Old Mar 8, 2018 | 09:08 PM
Greg's Avatar
Greg
Just another Corvette guy
Old Mar 8, 2018 | 09:14 PM
Rodnok1's Avatar
Rodnok1
Hard to reach bolts are difficult to get tight enough. I switched to ARP header bolts long time ago.
Use a good gasket..
Old Mar 9, 2018 | 02:41 PM
TimAT's Avatar
TimAT
And resign yourself to the fact that you will spend some time going back around and tightening the bolts again and again, Even with high quality bolts.
I tighten mine every heat/cool cycle for a few weeks, then just check them regularly. Gaskets compress, the header flanges "walk", and the bolts get loose. Trick is to keep them as tight as possible or plan on having leaks and replacing gaskets, which starts the cycle all over again.
Old Mar 9, 2018 | 07:00 PM
drwet's Avatar
drwet
25 ft lbs is about right. Problem is I can never seem to get that much torque on them because they are so hard to get at. Just keep retightening them. Same goes for the intake manifold bolts by the way.
Old Mar 9, 2018 | 07:27 PM
theandies's Avatar
theandies
Get good gaskets. I use Earls.
Get some good locking bolts. I safety-wire my bolts so they never loosen.
Old Mar 9, 2018 | 07:31 PM
gkull's Avatar
gkull
Anybody that has installed headers must say to there self that there must be a better way? Wouldn't you think?
They are called ARP header studs. You put the studs in the head with a little blue locktight or even red. Then you hang the header gasket in place and lift the header flange over the studs.
NoMess, NoHassle, Nocussing, nocrossthreading, NO Stupid bolts.
I tried everything. Lock wire, stage 8 bolt kits, double gaskets....... Then I found header studs. I have not touched a stud nut in years even with glowing pipes and felpro blue steel gaskets
Old Mar 9, 2018 | 08:21 PM
sunflower 1972's Avatar
sunflower 1972
I've always used header studs.
Old Mar 10, 2018 | 03:08 PM
joe1950's Avatar
joe1950
Thanks everyone
Old Mar 11, 2018 | 11:52 PM
theandies's Avatar
theandies
My safety wired (lock wire) bolts have never come loose and I think it looks cool AND I don't have to worry about them or a stud coming loose.
Just saying........
Old Mar 18, 2018 | 11:44 AM
Grumpy 427's Avatar
Grumpy 427
A long 3/8 wrench and long even pulls. No need to torque header bolts. Run the car then tighten again.
To Header Torque
