corvette choke starting procedure
Firstly apologies for asking a rookie question as this is my first carburetter car. 1969 corvette.
If i am cold starting the car, I pump the gas pedal a couple of times with the key in the on position and start the car. Does doing this automatically set fast idle? I know it sets the choke. I can disengage fast idle by blipping the throttle?
If I am warm starting (lets say the car was switched off 2 hrs earlier) the car I wont need to pump the gas pedal to set the choke? I can just start without touching the gas pedal?
If the car is somewhat warm and I set the choke then the choke spring will partially or fully open the choke valve depending on temp? Will the car still fast idle?
Essentially when should you apply choke and does fast idle automatically adjust itself?
Please let me know what the correct procedures should be for warm and cold starts.
Thankyou
There are starting procedures in the Owner's Manual.
They are for starting with a COLD engine.
Starting with a WARM engine.
Starting with an EXTREMELY COLD Engine.
Starting a FLOODED engine.
They all presume that the divorced choke is operating properly.
COLD.... Fully depress accelerator, slowly release, crank with foot OFF accelerator.
WARM ... depress accelerator about half-way and hold, while cranking.
EXTREMELY COLD....depress accelerator fully and release 2 or 3 times and then crank with foot off accelerator.
FLOODED engine.... depress and HOLD accelerator to floor while cranking.
Remember choke must be working. Have you been able to check it's operation with the engine both and at operating temperature?
Regards,
Alan
Choke in closed position, engine is COLD.
Choke in open position, engine is WARM.
Lars
Thankyou
fi is easy, turn key. fuel is under pressure and squirted
into cylinder.
computer controls everything.
carbs need air drawn thru to suck gas into cylinder.
when an engine is cold it needs more fuel.
that is where the choke blocks air intake and creates a
more fuel mixture to fire engine.
each carb engine reacts a little different to how much
extra fuel mix it needs.
how cold etc.
this will be learned by you as time goes on.
pressing the gas pedal squirts raw gas into the manifold.
this is done by pistons called accelerator squirters.
these allow for gas to be injected for increase in rpm when throttle opened.
this is where the 1 or 2 pumps come in before starting.
too many pumps will flood mixture and cause hard starting.
then you will need to figure out how much gas pedal you need to use,
1/4, 1/8, 1/2 pedal for starting a warm engine.
when fully warm, no pedal at all may work.
again, depends on engine.
so, pressing pedal squirts gas.
opening pedal allows air and fuel to be sucked in.
you will figure it out.
into cylinder.
how cold etc.
The choke appears to function correctly and had the fast idle set by my mechanic.
On cold start how long does it usually take for fast idle to drop back down to normal idle? I was advised to let the car warm up for 4-5 minutes
Your coil might be defective though.
Lars
