I too have a supercharged C3! I am SO subscribed! I have a friend that has a C&C machine. Would this be as easy as loading the specs (once you have them) and duplicate this?
It could be but I'm building axles and other parts to go with this.
Latest look at the hub, going to use the same bearing on the inside as the out allowing me to make the axle bigger 31 spline. Its @ 5.4 #
that's looks quite good, Im tempted to have a go at making a pair of these.
2024 I think you mentioned earlier in this thread, will you be hard anodizing them?
I decided to go with 6061 t6 my only area of concern is the arm, and as you can see I addressed that by beefing it up. I most likely anodize as a base for the powder coat. The axle wont be 31 spline it will be 1.367 21 spline, we use that spline a lot and keep the one machine set up for it.
Did the price make you faint?
How big of wheel and tire are you running or planning to run?
Not really I just have to decide if I want to build 6 sets or just blast through the one set. Hubs that is. I plan on 19x10 c6 wheels rear but may look at something that is more offset friendly.
Alum. came today for the hubs 6"x6"x 24" for the two.I dont know when Ill get to machining the parts as summer is here and a lot of family stuff going on.
