Electric Fan relay wiring
Old May 11, 2018 | 03:52 PM
Kyzarsoza's Avatar
Kyzarsoza
Originally Posted by lionelhutz
You didn't use an ignition switched source for the control circuit, but rather hooked it to a constant power source. Try switching it to a circuit that is only hot when the key is in the run position.
I have my constant 12v source going from my alternator to terminal 30 on the relay. My switched ignition source (plugged into male ign spade on fuse box) goes straight to a terminal (power in) on my temp controller. The second terminal on the temp controller then connects to terminal 86 on the relay.
Are you saying that I should connect my constant 12V source to the temp controller(ultimately terminal 86), and my switched power source to terminal 30?
Old May 11, 2018 | 06:20 PM
DUB's Avatar
DUB
Originally Posted by ronarndt
I put an explanation on another post that the IGN terminal supplies power only to the relay, not the actual fan motor.
But in this thread you are not clearly specifying the use of this wire that is being attached to the IGN terminal and going to the relay.
Which can be quite misleading if a person does no know where to attach the end if this a wire in relation to the relay.
DUB
Old May 11, 2018 | 06:32 PM
DUB's Avatar
DUB
I wish I knew what is going on with this controller and what it is doing.
I know what it deos and supposed to do...but not seeing how they want it wired has me confused.
I fell you are correct by having your constant 12 volt source at terminal 30.
And if you took the controller out of the equation. Using the IGN terminal in your fuse panel to supply switched power to terminal 86 is GOOD also.
And if you have your ground for the relay terminal 85 grounded.
And wire from terminal 87 on the relay going to the fan motor.
When you turn your key on the fan will run. And if you turn the key off...it should stop.
Then it is just figuring out the wiring for the controller....which is where I am lost due to knowing what it is doing when the sensor gets to temp and makes the controller do something.
DUB
Old May 11, 2018 | 06:35 PM
lionelhutz's Avatar
lionelhutz
No. The control circuit is the circuit that controls the fan, in this case the coil of the relay and the temperature switch which control when the fan in on or off.
As i already posted, even though you say it's ignition switched the control circuit is still keeping the relay on. If the ignition turned off all power to the control circuit there would be no power to turn on the relay with the key off.
Did you check that the ignition source does go off with the key?
Do you have some other wire connected you didn't describe?
Is the controller a temperature switch with 2 terminals or something more complex?
Old May 12, 2018 | 12:17 AM
Richard454's Avatar
Richard454
Simple test-
Next time the fan continues to run- pull the wire at the fusebox.
If that stops it- then you need to find another source- tapping right off the column mounted ignition switch - or at the radio would work. Then see what happens.
If it continues to run after pulling the wire @ the fusebox- go to the relay and pull (cut) the "controlled" wire on terminal 86-
If the fan continues- you've more than likely got a bad relay- or an incorrect one (foglight/timed/internal diode type)
If the fan stops when you pull 86 @ the relay- then something is wrong at the imperial 226203 controller.
Let us know what happens-
I hope I clarified it for you.
Richard
Old May 12, 2018 | 11:50 AM
Kyzarsoza's Avatar
Kyzarsoza
ill check my switch power supply today. The temp switch only has two terminals.
Old May 12, 2018 | 02:37 PM
Kyzarsoza's Avatar
Kyzarsoza
Well, the problem was my switched power supply. It was always hot. Changed over to switched and everything is working great. Thanks for all the help! It is always the simple things that get me. I just “knew” that I had my switched power source correct, such a DA.
Old May 12, 2018 | 05:00 PM
DUB's Avatar
DUB
I know how you feel.
It can happen to me at times where I would SWEAR that I have it correct ..and when I backtrack due to it is not working as I need it to work...it had changed...which often times makes me
DUB
