Your help needed.
Old Mar 25, 2018 | 03:38 PM
72 Project's Avatar
72 Project
Default Your help needed.
Front pad right side of engine: TT217CGV
Head casting # 336781
Old Mar 25, 2018 | 04:00 PM
Alan 71's Avatar
Alan 71
Hi 72P,
Not sure what if anything you're asking?
The suffix code... CGV... Indicates a 1970, 454 c.i./345 h.p., engine, built with a 4 barrel carburetor, for use with a manual transmission, in a passenger (full size) car.
Regards,
Alan
Old Mar 25, 2018 | 06:35 PM
72 Project's Avatar
72 Project
Thanks Alan 71.
The block casting number is 3963512. The seller say 70 Chevelle engine. I'm thinking of buying it to rebuild an put in my 72 vert it is a big block car but the original motor is long gone.
Old Mar 26, 2018 | 07:07 AM
Alan 71's Avatar
Alan 71
Hi 72,
It appears a 512 block would have been the basis for the 454 engine used in your 72 if it was a bb car.
The stamp:
Are you sure about the second T?
Might it be a 1 or an I used as a 1?
Typically:
T... Tonawanda
01 through 12... the month the engine was assembled
01 through 31... the day the engine was assembled.
3 letters... Broadcast Code
Regards,
Alan
Here's an example of the configuration for a bb stamp. (68-69 engines used a 2 letter broadcast code). Note the 2nd character. It's a 1.... so November 29 for the assembly date of this engine.
To Your help needed.
