Stud Girdle: When?
Old Apr 4, 2018 | 05:54 AM
bjankuski's Avatar
bjankuski
In my opinion you do not need a stud girdle. You are running a hyd. Roller cam that will be setup with seat loads in the 150 lb range and open pressures around 400 lbs. With 7/16 studs you will be fine. My rule of thumb is you don't need a stud girdle until you go with a solid roller cam that has seat pressures in the 250 plus range and open pressures above 600 lbs.
on a big block the stud girdle will change the lash once you tighten it down but it is usually only a few thousands. On a hyd roller small block the girdle may cause a lash change but since you set a preload on the lifter I doubt you will notice the change.
Old Apr 4, 2018 | 07:38 AM
L88Plus's Avatar
L88Plus
My builder/guru (R.I.P.) told me that I would need to start thinking about it at .700 lift.
He also told me that if you really need a girdle, you're nuts for not stepping up to a shaft system.
Old Apr 4, 2018 | 09:43 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
If the girdle is moving lash around when tightening.....there's something off with the girdle or the adjustment process. Never had an issue. The one I used for years on my engines was an ancient Moroso one bar one. Worked fine. Newer multi-piece ones shouldn't move anything either.
JIM
