Muncie fill plug repair help
Old Apr 10, 2018 | 07:48 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Duct tape!!!
Old Apr 10, 2018 | 09:10 PM
croaker's Avatar
croaker
Originally Posted by DUB
Easier said than done and not cost effective. The repair I suggested can all be done and not one bolt needs to be removed...other than the drain plug...obviously....so the threads of the fill plug can be cleaned really well....and the contact cleaner that may get in the transmission can drain right out and not hurt anything.
NO DRILLING OR TAPPING THREADS!
The process JB Weld told me did not even cause me to use a tap to cut new threads. The threads were already there when I pulled out the pipe thread plug.
I have used this process and I have repaired numerous threaded holes and did not need to run a tap into them.
DUB
so you basically glued the piece back?
Old Apr 10, 2018 | 09:50 PM
Big2Bird's Avatar
Big2Bird
Originally Posted by Jebbysan
My Vintage Hondas use the metric pipe thread........maybe one of these will work?
https://www.mcmaster.com/#pipe-plugs/=1ccfpws
Jebby
I'd try that for interim use. No pressure to speak of, just splash.
Old Apr 11, 2018 | 01:50 PM
4speeds's Avatar
4speeds
Originally Posted by 68notray
My M20 fill plug has been abused by previous owner to the point the normal plug threads all the way through without being tight enough to get a good seal, even with a ton of Teflon tape. Is there a slightly oversize plug available? Any repair short of welding and rethreading?
Some pipe plugs work on different tapers, so even if they are 1/2 npt, you may get lucky using for example some from a T5 transmission
Old Apr 11, 2018 | 01:56 PM
derekderek's Avatar
derekderek
they do seem kind of fat. lemme go measure one.
Old Apr 11, 2018 | 05:37 PM
DUB's Avatar
DUB
NO...The repair was put right back to like it would be originally. The knock sensor can be removed and tightened and did not nor has not leaked since the repair.
I re-created the missing casting with the JB Weld....and did not have to drill or tap any part of the repair. When the JB Weld cured....I could simply remove the threaded pipe plug from the JB Weld I used to create the threads and the thickness of the engine block that had fallen off.
DUB
Old Apr 11, 2018 | 06:48 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
what did you use on threads so the weld wouldnt stick to it
