Harmonic Balancer Bolt Differences?!?
Old Apr 11, 2018 | 04:13 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Default Harmonic Balancer Bolt Differences?!?
Help!
I picked up an almost new ATI balancer for a good price over @ ThirdGen. I tried the bolts that came with my aluminum pulley set and they won't fit. I bought a Mr Gasket SBC harmonic balancer bolt set (which included only Grade 5 bolts--is that an appropriately strong grade of bolt for a harmonic balancer??!?) and it doesn't fit either...
What the?!? Anyone know if the ATI balancers use a different size bolt?
#Confused.
Adam
Old Apr 11, 2018 | 04:27 PM
MelWff's Avatar
MelWff
what is the part number of the balancer that you purchased?
Old Apr 11, 2018 | 04:47 PM
derekderek's Avatar
derekderek
some use coarse thread. 3/8ths-16 instead of 20.
Old Apr 11, 2018 | 05:11 PM
NewbVetteGuy
I'll read the part #'s off of it when I get home.
I looked up the one part # I could find and it was just the part # for their SBC hub. (I THINK it's a 916951 because that's in my search history...)
The # I found on the balancer itself I couldn't find a match for online, but I can post it, too (although the bolt holes are obviously in the hub).
Adam
Old Apr 11, 2018 | 05:19 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Shouldn't be anything special. Just normal stuff on all the ATI's I've used...
JIM
Old Apr 11, 2018 | 06:01 PM
NewbVetteGuy
JIM
I was afraid you'd say that...
Adam
Old Apr 11, 2018 | 06:42 PM
DUB's Avatar
DUB
I am assuming you are referring to the three bolts that hold the pulley onto the harmonic balancer.
If so...YES...Grade 5 is good enough....but if you have concerns....then get Grade 8.
Either it is 3/8-16....or 3/8-24 or metric.
Take it to a big box home improvement store that have machine bolts in the hardware area...which I know they do....and find one that fits....or take it to you local NAPA that should also have bolts.
DUB
Old Apr 12, 2018 | 12:18 PM
NewbVetteGuy
The bolts that I have are definitely 3/8-24.
The bolt holes in the ATI Damper look courser than that and if I'm reading the ATI Super Damper Accessories page correctly, it looks like they require 3/8-16.
(Damper face bolts and pulley bolts are the same thing??!?) http://www.atiracing.com/products/da...arts/index.htm
Thanks everyone for your help! I was starting to fear that the threads were screwed up.
Part # on the hub: 916951
Part # on main body of the balancer: A379927
HA! I was able to take the hub part #, the outer diameter, and the fact that a magnet sticks to the case everywhere and reference the ATI Chevy part # chart to figure out that the balancer is a part # 917780
"Steel with Inner shell" I have no idea what that means or how it's different from the normal steel shell version (917785), but glad I finally have a part # considering that it's written NOWHERE on the part...
http://www.atiracing.com/products/da...s/damchevy.htm
Adam
To Harmonic Balancer Bolt Differences?!?
