New timing chain and gear
Old Apr 20, 2018 | 10:27 AM
c3_dk's Avatar
c3_dk
Default New timing chain and gear
When installing a new timing chain/gear set on a 69 then cylinder 1 has to be in TDC, and the crankshaft dot has to be @12 and the camshaft gear dot has to be at @12 also right?
If crankshaft dot is @12 and camshaft dot is @6 it is TDC for cylinder 6 right?
Old Apr 20, 2018 | 10:41 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
yes
when the dots line up
crank dot on top and cam dot on bottom is
#6 firing.
so remember to turn for number 1 for dist.
be aware of a 3 keyway crank gear.
1 for 0 1 for 4deg adv 1 for 4deg retard
Old Apr 20, 2018 | 10:47 AM
rklessdriver's Avatar
rklessdriver
Yes but even if you choose to install the timing gears (dot to dot) on the #6 TDC the camshaft and crankshaft will still be in proper mechanical time....
You will just have to turn the engine over a few times to get it up on #1 TDC to correctly install the distributor...
It won't matter which one of those methods you use to install the timing set... you can use the 12 and 12 method or the dot to dot method, because you are going to need to turn the engine over many times after bolting the timing set on.... for example when adjusting the valves.
Will
Old Apr 20, 2018 | 10:53 AM
c3_dk's Avatar
c3_dk
Originally Posted by calwldlife
yes
#6 firing.
Will
Thx both
I just had to be sure.......
Old Apr 20, 2018 | 11:20 AM
c3_dk's Avatar
c3_dk
yes
#6 firing.
BTW yes, as I remember it, the key for 0 is approx. @ 02.00 right?
Old Apr 20, 2018 | 12:33 PM
drwet's Avatar
drwet
This is what the timing marks look like when the engine is set to fire at #6 TDC.
Old Apr 20, 2018 | 12:47 PM
c3_dk's Avatar
c3_dk
Yes I agree, and the key is @ "02.00" o'clock
Old Apr 20, 2018 | 02:51 PM
HeadsU.P.'s Avatar
HeadsU.P.
"this is what it looks like when . . . . "
Only if you rolled your car over.
(had to say that)
Note the grade 8 bolts, the button and note the bolt locking plate ($5) cheap insurance. Good job!
Old Apr 20, 2018 | 07:17 PM
drwet's Avatar
drwet
[QUOTE=HeadsU.P.;1597040009]"this is what it looks like when . . . . "
(had to say that)
QUOTE]
OK. #9, BDC.
Old Apr 21, 2018 | 12:41 AM
c3_dk's Avatar
c3_dk
I thought it the very rare "up side down" engine, only made for people on the other side of the earth, and one year option only !! :- )
Old Apr 21, 2018 | 06:37 AM
HeadsU.P.'s Avatar
HeadsU.P.
It looks correct to our Australian friends.
To New timing chain and gear
