adding factory ps,pb?
Old Apr 24, 2018 | 04:22 PM
OldCarBum's Avatar
OldCarBum
Originally Posted by joeljet
don't even have the car yet but since these both sound very doable it makes the search a lot easier. I do want a/c though and wouldn't even think about converting that. as far as the work i'm a prof aircraft mech and can do all the above and I agree no hack work allowed.
again thanx for all the input. now I just gotta figure out how to save this thread.
Vintage Air makes a kit for that as well.
Many do it.
My 73 has factory air and I'll be removing the factory a/c and installing the Vintage Air.
Old Apr 24, 2018 | 05:25 PM
The13Bats's Avatar
The13Bats
Originally Posted by iwasmenowhesgone
The pushrod clevis goes into a different hole on the brake pedal, if you properly install it, on a manual brake car versus power brake car. You also need different stop switch brackets when you do this because they essentially swap holes on the brake pedal. Also, the manual master cylinder does NOT mount in the same two holes as ANY of the power brake holes. You might be able to BUBBA it, but it is not correct. The manual master cylinder holes are at least half inch lower than top holes of the power booster.
This is not a difficult conversion, but you should try to do it correctly by duplicating how GM did it rather than some of the cowboy stuff I have seen on this forum. But heh, its you car to rig it any way you feel compelled to do.
If you do the conversion, I would like to get that stop light bracket from your manual conversion so I can convert my power brakes back to manual.
Thanks im not a fan of hack job,
And just imagine the liability issues with modifications to how the factory set up the brakes...
Old Apr 24, 2018 | 11:27 PM
70Yellowbird's Avatar
70Yellowbird
Just above your original post, click 'Thread Tools'. Then click 'Subscribe To This Thread'. In the next window that pops up you can choose to be notified by email when a member adds a post, or you can subscribe w/o notification. Go to 'Quick Links' (located a little above Thread Tools) to find a list of the threads you have saved (Subscribed to).
Old Apr 25, 2018 | 05:32 AM
terrys6t8roadster's Avatar
terrys6t8roadster
If you click on the usercp and scroll down all the post that you have contributed to are listed. T
