Alternator bracket passanger side
Old Apr 24, 2018 | 02:21 PM
Rimfire's Avatar
Rimfire
Default Alternator bracket passanger side
Dear USA colleagues
Greetings from North, Finland!
I have below SBC setup at my 69 Vette and belive that I need to mount the alternator to the passenger side. As you can see there is a Moroso Electric Water Pump and the hyraulic pump for PS and brakes.
SBC 434 over all pcture
Here is little detail related pulleys:
The alternator pulley would be the the outer one. The inner one could be used for that too I think. The measurement here is in centimeters
Any similar setups and what bracket you recommend me to use?
BTW. I used to have the alternator at the driver side and used the inner pulley to drive both the alternator and PS pump (same PS pump as in the picture). Now I'm adding Hydroboost for brakes and I think that the belt contact surface would be too short => need to change something.
Old Apr 24, 2018 | 04:13 PM
HeadsU.P.'s Avatar
HeadsU.P.
Well, you have plenty of holes in your head (pun intended) for some type of bracket.
I also see that the waterpump bolts of that "flush type" are of no help.
Perhaps March has something to bolt to the end of the head.
At least the fuelpump will no longer be in the way.
Old Apr 25, 2018 | 01:02 AM
Rimfire's Avatar
Rimfire
Hmm.. not too many options. This one might do the trick:
https://www.summitracing.com/parts/mch-20132
At this point I'm willing to spent $200, expensive though.
Old Apr 25, 2018 | 06:15 AM
Rimfire's Avatar
Rimfire
Any thoughts about toothed pulleys?
Toothed crank pulleys seems to be hard to find (from Summit) and only two alternator pulleys seems to be available.
This leads to conclusion that toothed pulleys are not used for alternator / hydralic pumps. Why, I don't know.
Old Apr 25, 2018 | 06:31 AM
HeadsU.P.'s Avatar
HeadsU.P.
Obviously a toothed pulley system does not allow "slipage". I guess there are some places you want slipage to protect that particular piece from an overload maybe: ALT, W.P, P.S. ???
I guess there is NO WAY of installing that crank-pulley right in front of the harmonic balancer? I does not appear to be reversable, but wouldn't that be slick?
To Alternator bracket passanger side
