Pertronix ?
Old Oct 17, 2002 | 10:17 AM
itza56's Avatar
itza56
Default Pertronix ?
Has anyone switched from point's over to the Pertronix system ?
What has it done for you ?
Good ? Bad ? is there much to it ??
Old Oct 17, 2002 | 11:00 AM
pws69's Avatar
pws69
Default Re: Pertronix ? (itza56)
I put one in mine last year (fresh engine, carb), but the car is not really on the road yet - just a few quick jaunts up the street. I noticed right away that it started much quicker and smoothed out the idle. On the other hand, as I approach official roadworthiness, I am beginning to get a little concerned based on MANY negative comments I have seen about people getting stranded, etc. What I am now VERY sure of is that I will ALWAYS have a set of fresh points and the tools to convert back in the car. The first time it dies, it will be gone.
Old Oct 17, 2002 | 11:13 AM
johns73's Avatar
johns73
I switched to pertronix it was easy to install, no more setting points and it delivers more spark i relly noticed a performance diffrence. :)
Old Oct 17, 2002 | 11:26 AM
MELVIN's Avatar
MELVIN
Default Re: Pertronix ? (johns73)
Lotsa miles on mine. No prob
Old Oct 17, 2002 | 11:45 AM
Solidlifters
I haven't done it on a Corvette, but my 67 500 Shelby was always kinda hard to start, especially when hot and didn't idle real well either. I put yet another kit in both carbs and finally put a new set of carbs from Holley which they sell as replacements for all the FE engines that came with 2 4's from the factory. The new carbs did help the driveability some but the car was still unpleasant at times. The Pertronix made a different motor out of it. I don't know why all the difference, but it cranks and idles as it should. The first day I had it in, I went through a yield sign in second and realized a car was coming faster than I thought. I went down on the gas and it lit the tires. This car has never been responsive like this before. I don't have a lot of miles on it, but I'm 100% sold. I bought their recommended coil also.
Old Oct 17, 2002 | 12:57 PM
jessed's Avatar
jessed
I just put the HEI rebuild kit from Pertronix, and it is awsome. Faster start and a much smoother timing advanced. Very :cool:
Old Oct 17, 2002 | 01:55 PM
Surfer69's Avatar
Surfer69
Default Re: Pertronix ? (jessed)
Only thing is you have to give 5 seconds with key turned on to "charge" before turning engine over. Some reason it needs to be energized or engine turns for few seconds before starting. Other thing is they only last 3 years of daily driving, so you can be stranded if you dont watch for the signs of it starting to fail.
To Pertronix ?
