Injection, phasing in the rotor.
Apr 29, 2018 | 01:12 PM
Small question here, what was your staring point on the ignition, how many degrees? (it for a small block 400hp street motor.)
Apr 29, 2018 | 02:07 PM
Not sure what you're asking? You mean timing advance when cranking? I use 15 degrees. Idle is 27.
Or are you asking how to phase the rotor? For that I set the crank to 30 degrees and then adjusted the distributor so it lined up to the terminal.
Apr 29, 2018 | 02:22 PM
Quote:
Originally Posted by
zwede
Here we have a Fitech system we have to install on a SBC.
The manuel is saying 10 degrees on the crank, depending on the motor (Ford, Chevy ec ec)
I was wondering, instead of 10, maybe it must be 15 or 16 degrees when it's a SBC, or maybe it doesn't matter?
Apr 29, 2018 | 02:37 PM
Holley recommends 15 for cranking so that's what I've always used.
Apr 29, 2018 | 02:40 PM
zwede
Ok we will go for 15 degrees.
I have EZ-EFI 1.0 in my car, but now I want EFI with timing control !!!! :- )
This is great :- )
Thx for your help.
