New front seal leaking
Old Apr 30, 2018 | 12:59 PM
Surfer69's Avatar
Surfer69
Default New front seal leaking
I just rebuilt my engine and made sure I did everything prep wise correct. I bought the standard blue Fel Pro timing cover HB/crank seal and made sure it was lubed a bit before start up.
Now the thing is leaking and I have to fix it. I am using a full synthetic oil which maybe is too thin for this seal.
Guess I want to know if there is a super duper heavy duty seal made by anyone for SB chevy or that can handle thin synthetic? Thx
Old Apr 30, 2018 | 01:32 PM
derekderek's Avatar
derekderek
Possibly you have a seal cut in the balancer lip. If so, dont put the seal in all the way.
Old Apr 30, 2018 | 01:40 PM
drwet's Avatar
drwet
Also I have had better success when I pack the space between the lips of the seal with grease.
Old Apr 30, 2018 | 01:43 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Use one of the sleeves on the balancer to cover any grooves and make it just a little tighter. All parts stores have them.
JIM
Old Apr 30, 2018 | 05:00 PM
Surfer69's Avatar
Surfer69
JIM
Sorry Jim I didn't follow. All parts stores have what exactly?
Old Apr 30, 2018 | 05:05 PM
ezobens's Avatar
ezobens
Some places call it a 'Speedy-Sleeve'.
It's a thin metal sleeve that you press on the end of the balancer hub to cover up any grooves that may have worn in the hub from previous seals (assuming this is a used balancer).
Helps with front seal leakage issues if your hub is less than pristine.
Old Apr 30, 2018 | 05:42 PM
Surfer69's Avatar
Surfer69
Got it. Perfect idea. Thanks guys.
Old Apr 30, 2018 | 09:59 PM
'75's Avatar
'75
If you install the seal with a hammer, sometimes the shock will knock out the spring on the back side. Pack it with grease to stop it from happening. If the spring has fallen out, you should be able to work it back onto the seal lip with a couple seal picks.
To New front seal leaking
