I am wondering if I can disconnect the power steering from my 1973 stingray and still be able to turn the wheel. I hab a 68 without PS and it drove just fine.
Why you might wonder would I want to do that? I have been fighting leaks for the last several years an am struggling with the constant mess. .
Can I take it out and still be drive it ?
Thanks,
Steve
No, it will not steer like a regular non PS car. The steering box is completely different and meant to be used with hydraulic assist. If you just disconnect the hoses and try to drive the car the steering will be extremely difficult and dangerous. If you really intend to delete the power steering you will have to change to a manual steering box.
[QUOTE=Peterbuilt;1597105600]Corvettes use the same steering box for power or non-power steering.
Just remove the fan belt and see if you like it or not.[/QUOT
E]The outer tie rod ends go in a different hole, It will be very hard to steer
Not true on a C3. It uses steering assist and not power steering. The only difference may be if a previous owner used the fast hole in the linkage and you may want to set it back to the slow hole. I would remove the steering assist cylinders so not trying to push fluid too.
The steering box IS the same box,....but if you leave the power control valve connected, without hydraulic pressure, I believe there will be a huge amount of excessive play. I don't believe you can just remove the power steering pump belt and think it will operate like a factory manual steering car.
By the way, I converted my 77 factory power steering to factory 76 and earlier manual NON power steering, and the car drives incredible. It drives like a sports car should, with fantastic road feedback and very tight steering. It changed the steering from sloppy and scary steering to a fantastic sporty feel. Anything over 10 mph, you can drive with a finger, but at parking lot speeds, and maneuvering, it does take some physical effort, but its a minor inconvenience. It made the car fun to drive.
To agree and also confirm that the gear boxes are the same. The gear box is not specifically made or non-power steering or power steering. They are all the same in that regards.
YES...moving the tie rod ends to the outer holes of the spindle arms will greatly help and reduce steering effort. THIS will also require getting the toe setting corrected at an alignment shop.
I can not confirm or deny if the effort will increase IF the power steering system is left intact and the fluid is being moved in and out of the power steering cylinder. I can visualize it and being highly plausible.
If you have a leak...eventually the fluid will all leak out and you will be not moving much of anything...depending on where your fluid leak is currently.
My 70 has no power steering and I put the tie rod ends in the fast hole and its not that big of difference. Maybe a little harder to park but it feels better going down the road.
My 73's power steering leaked when I bought it two years ago, I repaired it and it's starting to leak again. As part of my body off resto/mod I'm removing all the OEM power steering components and going with a borgensen box that eliminates the slave cylinder and two hydraulic lines under the car.
The borgenson box is supposed to be a big improvement over the OEM steering and I haven't seen any threads from people who have converted over to having any leak issues after converting over.
the best way to do this is with a non PS relay rod and pitman arm, I have an extra in "bolt on" condition, send a PM if you or anyone else is interested...
Thanks to all for the input. Still a little confused as to the need to change settings ( fast or slow ) but it does appear that it is possible..
The two holes in your steering arm that is attached to your spindle are there for the two different designs of steering available.
I do know for a fact that IF you have power steering and put your tie rod end in the outer hole...you will regret it. The steering is so hyper- sensitive that it is about impossible to steer safely.
IF you have manual steering...the outer hole provided more leverage and make steering not so hard.
So changing the position of your outer tie rod end is to aid in the amount of effort you will need to use to turn the wheel. Or leave it and see if it is good enough for you.
That unit is much like the units GM used on other cars...and YES...they seem to be less problematic when it comes to leaking.
