Break Fluid Gravity Bleed
Old Jun 23, 2018 | 12:03 PM
derekderek's Avatar
derekderek
All brake lines are the same age. And the front brakes do virtually all the stopping. If you lose a rear line, you will feel pedal change, but you won't be buying the guy in front of you a new car...probably. So replacing the entire front system is a good idea.
Old Jul 24, 2018 | 07:36 AM
ZRXGreen's Avatar
ZRXGreen
Can gravity bleeding be done with the stock bleeder screws? Or do you need speed bleeders?
Old Jul 24, 2018 | 08:26 AM
Vette_Newbie1's Avatar
Vette_Newbie1
To answer your question, Yes. Stock bleeders can be used.
Speed bleeders cannot be used. After some quick research, it seems that you need some pressure (either force from a pedal or suction from a vacuum) in order to open the 1-way valve on the speed bleeder. https://www.motorists.org/blog/how-to-bleed-brakes/ <--This website is a nice quick read on gravity bleeding your brake lines. It addresses speed bleeders at the end.
