Vaapor canisters
Old May 4, 2018 | 08:17 PM
skynut52's Avatar
skynut52
1st Gear
Default Vaapor canisters
1981 350 vapor canister filled with any ideas why?
Old May 4, 2018 | 08:19 PM
Greg's Avatar
Greg
Just another Corvette guy
I don't understand what you're asking?
Old May 4, 2018 | 09:26 PM
kansas123's Avatar
kansas123
Charcoal....
Old May 5, 2018 | 06:28 AM
Alan 71's Avatar
Alan 71
Gas....
Old May 5, 2018 | 07:06 AM
biackbenz's Avatar
biackbenz
Canister is filled with carbon. The carbon absorbs gas fumes. You have a lines coming from your gas tank to this. There are four lines between the canister and the carb at least there are on a 78. When running the cab circulated air through the canister into the carb and burns those fumes.
Old May 5, 2018 | 07:49 AM
Tooch1's Avatar
Tooch1
Here is what is inside that canisters. I opened one up. As a matter of fact I've opened up a couple to restore. Easy- fun- DIY- project. You need to remove the lower cover to access the inside. This is from a '73 but you get the idea. You can purchase the activated charcoal at any pet store. Same as used in aquariums.
Corvette vendors and local part stores sell the lower filter. However, the foam filter above the charcoal is not. I purchased a sheet of window air conditioner filter material from the local hardware store. Worked well.
Hope this helps,
Tooch
To Vaapor canisters
