I was looking into poly bushings for the rear sway bar on my car. I was curious your experience installing them. The urethane bushings are flanged at both ends, meaning you can't get them thru the opening on the swaybar or link. If you bolt them in per the instructions above (right side) you have a metal-on-metal contact from the bar to the link and from the link the seat.
If you use the stock bushings (left side) you have rubber contacts at both side.
Am I reading the installation instructions wrong?
I am using poly for my rear sway bar but the VB&P setup is different; basically the same style as the fronts.
Looking at the picture you provided it would seem that the bushings must either be split and meant to be applied one from each side (this is what I would expect), lined up with the steel inner sleeve, and held in place by the OEM endlink when installed. If the bushings are in fact one piece then it must be intended that the bushing is somehow pushed through the opening of the sway bar. I have seen these types of bushings as well and basically you grease up one end, set it on an angle into the hole at the sway bar and 'screw' it into position with a twisting motion. The material compresses enough that it will thread through the opening and pop into place once it reaches the center section of the bushing.
One thing I can tell you for absolute certain is that there should be no metal to metal contact there.
Sounds like you are reading the instructions wrong. I fitted a set of these today and you can push the bush through the sway bar and the link. you just need to use a vice or a nut and bolt to apply a bit of pressure and they slip in easily.
Poly bushings are known to bind when used on trailing arms and strut rods due to the fact they pivot laterally as well as axially.
Good points.
Which is why my Van Steel offset TA's have johnny joints on the front.
And my strut rods were replaced with adjustables with heim joint ends.
You were right. I used channel locks with a flat washer and a wide socket and they went right in.
Much ado about nothing.
Thanks!
Thanks Dub for the info on the *adjustable greaseable heim jointed strut rods, I'll look at those for sure. I'm 65 so I remember what the C2 ,C3 vetts rode like new and they drove and handled amazing! I'd like to get mine handling as well as what I remember, I'm changing the body rubbers also. : )
Dub is no longer with us in this forum. Also some of what he says has been found to be caused by subpar quality poly bushings a very popular but now defunct vendor on here was selling. If you stick with a quality brand on poly like extreme energy I've found no reports of those bushings hardening and crumbling like the cheap stuff.
That said I use heim joints on my adjustable strut rods myself and poly elsewhere. I bought the cheap adjustable rods that came with the poly ends, then removed those ends and replaced with the correct sized heim joints which cost about $40 on amazon so I was able to do it myself for about $150 total.
